Question about Mr. Coffee TFTX85 Coffee Maker
Mr. Coffee TFTXC85
Mr. Coffee TFTX85 shuts off before it is done brewing. Where can I get parts to fix this problem?
    Sergeant:
  • 199 Answers
Run 2 cups of vinegar through the coffee pot brew it do it twice. this will clean the calcium out. then rince out out and brew one batch of water to clean.
Posted on Jun 23, 2009
BVMC-PSTX91 MR COFFEE....ONLY USED ABOUT 15 TIMES AND NOW LONG BEEP AND WONT BREW...THE BEEP WONT GO AWAY UNTIL YOU TURN OFF THE MACHINE
Mr.Coffee guarantees their machines for one year from the date of purchase. If you still have a receipt I would contact them. If not there could be a problem with the board on the inside of the machine. Which, unfortunately, is not available yet to purchase so your machine can be fixed.
Nov 12, 2010 | Mr. Coffee TFTX85 Coffee Maker
Water does not come out ...is there a fix
mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Jul 09, 2010 | Mr. Coffee TFTX85 Coffee Maker
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Coffee won't brew - lights turn on - clock works - clicks little.
2 years old I would pitch and buy a new one.
Cleaning generally won't help a machine that does not work.
Heating element has probably burned out.
(I am not talking about the heating pad for the carafe!)
For future reference for all the coffee drinkers out there:
Simple quick way to clean a drip coffee maker is use Vinegar.
Let it brew through the system as you would water.
Discard and run fresh water through the system to clear out the vinegar residue left behind. (Make SURE the system has cooled first before running the fresh water through!)
For those that have hard water and the coffee tastes funny.
Try a small pinch of salt in the filter basket ON top of the coffee grounds. This will soften the water and hopefully take the bitter taste away.
Guess it is possible large enough calcium deposits could block the hole in the holding tank to prevent the water from percolating to the filter basket. You may wish to check this before tossing. Last minute thought before pushing the post button.
Oct 04, 2009 | Mr. Coffee TFTX85 Coffee Maker
6 month old model JWX27 has display power, but wonit won't brew. It clicks when I push the brew now button, the plate doesn't even heat up.
I HAD A COFFEE MAKER DO THIS AND I TRYED TO GET PARTS FROM THE MANUFACTURER AND THEY WANTED ME TO SEND IT BACK TO THE FOR REPAIRS THEY DON'T WANT THE LIABILITY OF SOME ONE GETTING HURT . BY THE TIME I SHIP THE THING AND PAY FOR PARTS AND LABOR I CAN BUY TWO NEW COFFEE MAKERS. YOU MAKE THE CALL
Aug 11, 2009 | Mr. Coffee TFTX85 Coffee Maker
My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Jun 23, 2009 | Mr. Coffee TFTX85 Coffee Maker
Coffee won't brew
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Sep 17, 2007 | Mr. Coffee TFTX85 Coffee Maker
I despise the TFTX85!!! It will overflow, it will stop working! It will never tell you the correct time! It is evil in a coffeemaker. Check out our problems with this piece of junk at pisymphony.com ( opinions)
Apr 10, 2007 | Mr. Coffee TFTX85 Coffee Maker
Water is not heating
Sep 26, 2006 | Mr. Coffee TFTX85 Coffee Maker
Mr. Coffee TFTX85 Coffee Maker Logo
490 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
