Axis Cd Tower
Having problems seeing the tower over my network, replaced the controller, nic and cable.
  • Wendy Bauman
    Wendy Bauman May 22, 2008
    Also connected to the tower with a laptop and cable to the back of the tower was able to see the address and get into the cd's, but when I came back to the office and ran a ping to the servers it shows the CDtowers being down, I have full connectivity, all LED lights are active LAN coneection is good, and Power is good.
    Genius:
  • 3,422 Answers
I have a very littler idea about your problem,it would be better if you can consult another expert about this.
If you need any other help let me know.
Thanks..
Posted on May 22, 2008
Greetings, My DVD duplicator tower only burns cds, Any ideas?
I would say reinstall the drivers for the tower & look for updated drivers from the manufacturer web site. Check all cabling since a bad cable could cause a lot of errors to happen slowing things down. If it was just one drive it could be the drive or a drive is causing the problems. You can disconnect the data cable of one drive at a time to see if the others speed up indicating. Have you installed any software just before the drives started acting up. Other than that I would call tech support of the tower manufacturer. I would assume having it 3 month's your warranty should still be good. Hope you have luck in fixing it.
Bob
Oct 23, 2014 | Computers & Internet
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Removing current cd/dvd burner from tower to replace with new one can't seem to get it out.acer tower, not real smart with computers sorry
most CDRW drives are secured using 4 screws (2 on each side) which means you have to remove both side plates of the tower to remove the drive, sometimes manufacturers use rails which "clip" the drive in place and are removed via the front instead (sometimes having to remove a retaining screw).
after that the drive is only held in place by the connected cables.
Sep 22, 2008 | Computers & Internet
AXIS CD TOWERS
I am assuming that you are referring to the tower (desktop) as the server while the laptop is the client. While the client can access the server's CD drive, you can not ping the server. A couple of ideas:
1. verify that both server and client belong to the same Workgroup;
2. verify that both server and client have the same Subnet Mask and that their satic IP adds are near each other;
3. Server's firewall settings/configurations does not allow/prevents ping response; and/or
4. the server might be using Zonelab, McAfee Firewall, Microsoft ICF SP2 or some other form of port blocking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 22, 2008 | Computers & Internet
AXIS CD TOWER Problems
I'l get back to you, got some stuff to do right now but here are the manuals for your product maybe you can find a solution there untill I get back.
http://www.axis.com/techsup/cdsrv/cd_e100/index.htm
AXIS CD TOWERS E100
I am sorry, but this is not really my area of expertise. You could try Ekse or Benimur who are good at networking.
You do not have to rate this post, as I did not really provide a solution.
Can't see the Axis over the network
Solid green lights usually mean no activity. Have you checked the Network Card properties and made sure you are using DHCP? Are you plugging into a switch? Is the switch on the same network as your DHCP server? Have you tried different ports on the switch? Also, is the duplex set appropiately?
Problems with IP address
Possible three (3) solutions:
1. Purchase and install a PCI LAN card (NIC) inside your "old tower". Should not be that difficult using any available PCI slot. Most would be auto detect/install by Windows (XP) or should come with a driver CD;
2. Use a USB to Ethernet adapter/converter; and/or
3. Use static IP address for the tower Same IP add (+1 on the last digit, same Subnet Mask, Default Gateway and DNS (if any). Should you need additional information on this method you need to post back details of your modem (brand/model, normally in a sticker underneath) so we can determine if it will allow simultaneous connection on USB & LAN.
Hope this be of help/idea. Pls post back should you need additional information.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
Procom CD Tower Ethernet CDT 7-E2
sun microsystems bought them out. speak with them
Jan 23, 2007 | Procom CD Tower Ethernet CDT 7-E2...
Open Questions:
Instant US''1-:877-:778-:89:-69''AVG Antivirus Tech Support Phone Number? 1-877-778-89-69 AVG Antivirus service phone number is solve the matter of virus's. 1-877-778-89-69 is loosely used in USA. It offer the ability of 24*7 services. AVG Antivirus customer care service number's executive able to solve the any virus problem with the assistance of AVG antivirus support phone number.It doesn't matter from wherever you and at what time you need help. For know about us:-1877+778+89+69 If you want to the best solution for your Antivirus problem you must call our technical phone number 1-877-778-89-69. Our technical experts suggest you to fast and easy way to protect your device. Just Dial Our TollFree Number 1-877-778-89-69 and get full protection for your device.In case of any Antivirus problem must dial our AVG Antivirus Support phone Number:1-877-778-89-69. AVG Antivirus Support Phone Number, AVG Antivirus Customer Service Phone Number, AVG Antivirus Tech Support Phone Number, AVG Antivirus support Helpline Number, AVG Customer support Telephone Number.AVG Helpdesk number,AVG Tech support Telephone number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number.
May 29, 2017 | AVG Computers & Internet
Computers & Internet Logo
46 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
