Question about Weather King 10AJA2501AH Air Conditioner
Size and SEER rating
Could you tell me the size and SEER rating of a 10aja2501
  • 828 Answers
2 ton (24,000 BTU) 10 SEER
Posted on May 22, 2008
What is the best size kw. ANY BRAND Air Con is Equivalent to suit Air Con : Conia Air Con Model : CA242 S/N:ca24220970353
KW is not the number that you need to be concerned with. The newest rating for HVAC is called SEER. If yours is older it might be listed as TON.
Dec 09, 2016 | Heating & Cooling
Trying to determine what size capacitor my unit C1048BBD1VF uses for my AC unit. Is it larger then a 45 amp? Replace it with a 45 and you can hear it try to turn on but it won't.
capacitors are rated in microfarads or picofarads and not amps
capacitors are used to provide a boost voltage to start motors and then to keep them running
Amps is current flow so what ever you replaced was the wrong unit.
on the side of a capacitor will be voltage rating (110-115-220-240 etc and a number 45 -55 60 uf etc
it will have either 2 terminals or 4 terminals connected as pairs
from what you describe it is a capacitor problem
May 26, 2016 | Airwell Fedders Fedders C1048bbd3vf 3...
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
I have 2 Weather King units model numbers 10AJA2501 & 10AJA6001 and am trying to determine the sizes and SEER ratings of each
Hello Larry Both units are 10 SEER.Standard rating ,not efficent units.JA25 is a 2 ton unit,JA60 is a 5 ton unit.Thats 24,000 BTU & 60,000 BTU.I hope that helps.
Jul 08, 2010 | Weather King 10AJA2501AH Air Conditioner
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
What size condensor is this? Can I buy a replacement in Augusta, GA?
I think its 2 ton.replacements are avalible but not 10SEER.12+SEER replacement available.maybe time to upgrade?Give mod. # off the compressor to confirm your size.
Mar 16, 2010 | Weather King 10AJA2501AH Air Conditioner
I HAVE A GOODMAN FURNACE GMS8 WHAT IS THE LARGEST SEER RATED AIR CONDENSER WILL WORK WITH THIS UNIT.
seer is not a problem....18 would be fine.depending on the size of the blower,you may have limitations on tonnage of the ac.
Sep 10, 2008 | Heating & Cooling
Air conditon units
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
May 19, 2008 | Heating & Cooling
Weather King 10AJA2501AH Air Conditioner Logo
317 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
