Question about Tomtom ONE 3RD EDITION GPS Receiver
BRIGHTNESS AND CLOCK SET ARE GREYED OUT, INOPERABLE
I HAVE THE TT1 3RD ED. IN THE US, BUT I IMAGINE IT'S THE SAME? FOR SOME REASON, THE CLOCK IS 4 HOURS AHEAD OF WHERE IT WAS ORIGINALLY SET. I ALSO WANT TO CHANGE THE BRIGHTNESS TO SAVE BATTERY POWER.
SORRY 'BOUT THE CAPS, i WASN'T LOOKING :-(.
  • 2 more comments
  • Herbert Fellows May 22, 2008
    The brightness and clock are both greyed out in the preferences menu??
  • minidanas Jun 07, 2008
    Same here
  • Anonymous Sep 08, 2008
    Same problem - clock is 'grey' in preferences so I can't get into it.
  • essex11 Sep 08, 2008
    Clock is 'grey' in preferences so I cant get into it to change the time. Any suggestions please?
On the tomtom one goto change preferences,click on the arrow to the 5th page and click on set clock. you should then be able to set the correcttime
i had the same problem
let me know if that helps
Posted on Jul 07, 2008
  • 28 Answers
Hmm for the TT1 I believe there is a way to change your time in the settings menu, but I no longer have one in front of me to figure it out, you might check for something like time and date, or time zones, also the brightness can be set under brightness/ or Contrast. That is found in the preferences menu, i will try and get my hands on one of those to be more accurite for you.
Posted on May 22, 2008
How to make the led brighter
To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
Jan 18, 2014 | Sony ICFC218 Clock Radio
Viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Mar 09, 2010 | Computers & Internet
The timer on my panasonic th50px50u is greyed out and i can't set it. can it break or stop working?
I had the same problem. I fixed it by going to menu > setup > restore to default. I had to readjust my picture settings and relabel all my hdmi connections but it fixed the sleep timer.
Feb 27, 2010 | Panasonic TH-50PX50U 50 in. Plasma HDTV
We want to reset the clock from am to pm or start beginning questions all over again.
1. Turn on the TomTom unit. 2. Tap the screen to bring up the menu. 3. Tap the "Change Preferences" icon 4. Keep hitting the arrow to go to the next page. Clock setting is on page 6 of the preferences dialog. 5. If the Set Clock option is greyed out, you will need to perform a system reset and then perform these steps over again.
To reset the system, start with the power off. Then, hold down the power button for about 15 seconds, until you see the TomTom logo appear on the display. When the logo appears, release the power button. After this reset, you should be able to turn the unit back on and proceed with your setup from scratch.
Nov 27, 2009 | Tomtom XL 340S Car GPS Receiver
Have installed Logitech pro 9000. Install is incomplete. Don't have privacy control. Don't have effects control. Camera controls such as pan, zoom, brightness, etc. are there, but are "greyed out" and...
Try reinstalling the CD Software program.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 04, 2009 | Logitech QuickCam Pro 9000 Web Cam
Will not let me change time setting
I just disconnected from the computer and manualy went through change preferences arrows until I got to set clock. I was then able to set clock. Thanks
Nov 19, 2008 | Tomtom ONE GPS Receiver
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
Set Clock Greyed out
I have the same problem - clock set is grayed out. Called Panasonic tech support .. this is the solution I was given. It works, but too bad the root problem can't be fixed (bug ridden unit).
Solution is to "reset" the unit - then go back into the menu system and set the clock. How to reset the unit (don't worry - anything on the HD stays intact):
1) go to DVD mode
2) remove any DVD in player & close tray
3) on front panel, behind door - press & hold BOTH channel up & down keys for 5-10 secdons -- until you see a message that the system is rebooting
4) wait till it reboots, go back in the menu and set the time.
-Craig
Nov 05, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Tomtom ONE 3RD EDITION GPS Receiver Logo
294 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
