Question about Intertherm P3RA-030K Air Conditioner
Reset Button Where is the reset button located.
Model # P1RA-030K - sereal # P1R970301149
a/c intertherm
house thermastat wiring
y is green wire
rc- red wire
g- white wire
a/c unit y- green-blue
rc- red-red
g- white- yellow
help is this right
Posted on May 26, 2008
  • 828 Answers
There is no reset button on most of these units. If nothing is running at all when a call from cooling from the thermostat is made your problem could be a tripped or breaker in the off position. When you turn the thermostat to cool have someone listen for a click at the unit. If no click is heard it may be in the low voltage circuit that your problem is. If a click is heard which is the main contactor pulling in to run then your problem may be in the high voltage power supply. If you have a fused disconnect check the fuses. They should be of the time delay type (slow blow) and sized according to the ampacity on the unit name plate. Also check the main breaker in the house power panel.
Posted on May 22, 2008
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: where is reset button located
Look real hard on the remote. There is a mini "use a ballpoint pen" push to reset filter button on the remote.
Electronic control panel: (not all models)
Hold the mode button and the Temp Up arrow depressed for about 5 seconds. It should display the temp and the FL should disappear.
Thanks for choosing FixYa.
Kelly
Posted on Sep 05, 2010
kel1guy2002
  • 3740 Answers
Look at your remote carefully. There is a bal pen type push to reset filter button on the remote. Depress the rest button and it should reset. Also on the contol panel you can also reset it by depressing the mode and the UP temp arrow buttons for 5 seconds.
Kelly
How can I reset my Polaroid Tablet?
In the event that the tablet freezes or does not function properly, press the RESET button located on the bottom panel.
Follow the link to see the diagram of where to find the switch, it is in the bottom left corner of this web page. Zoom to maximum (200%) to clearly display the picture showing the location of the reset button.
The button is tiny, you will need to use a paper clip or the tip of a stylus to press the RESET button.
Data stored on the tablet will not be affected by using the RESET button.
The location of the reset button is the same on all models.
http://www.polaroidstore.com/store/images/pdf/pmid1000-polaroid-wifi-internet-tablet-with-touch-screen.pdf
May 24, 2014 | Polaroid 4.3" Internet Tablet
Reset button location
To perform a hard router reset, keep the router powered on. Then, find the unit's reset button, often located on the rear of the device. Use a pen tip or bent paperclip if necessary to depress the button and hold it down. Network administrators are taught to hold the button down for 30 seconds; your router probably does not require waiting that full length of time, but this is a good general rule to follow. After releasing the hard reset button, a router may need up to 1 minute to reboot and resume normal operation.
An alternative method for hard resets involves holding the reset button down for 90 seconds instead of 30, unplugging the router from power and then re-plugging it partway through as described in these instructions for the 30-30-30 hard reset rule. This more involved reset process may not work on some routers and should only be tried if the basic 30 second version does not work.
To avoid Internet connectivity complications, disconnect the broadband modem from the router before performing hard resets.
Mar 01, 2014 | Computers & Internet
Were is reset located inside rcag35831at
The reset button is used to return the unit to its factory settings.
Step1: Turn on your vehicle, but do not start the engine.
Step2: The reset button is located on the right hand side of the deck. Just to the right is the reset button. It is a circular shaped button the size of a pencil lead thickness and it is not labeled. If you have trouble locating the button, use the flashlight to help illuminate the area.
Step 3: Depress this button. If you have do not have smaller fingers, you may need to use a pencil or pen to depress the reset button.
Regards
BEADHZ
Mar 18, 2013 | RCA G35831AT 35" TV
How do i reset
The first method involves using the reset button that is located at the back of the router. It isn’t hard to reset the router this way, but does require physically being in the same location as the router.
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
Aug 31, 2010 | Linksys WRT160N Wireless Router
Just used garmin nuvi it worked fine went into the store and now the unit is locked/frozen on the garmin logo screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Make sure to charge it fully.
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Do a RESET:
  1. Lift the antenna
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 260W screen is blinking and beeping. Wont do anything else
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sure give it a try.
  1. Lift the antenna
Aug 02, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
  2. Locate the small circle with a dot inside (very small)
  1. Lift the antenna
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
  1. Lift the antenna
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Intertherm P3RA-030K Air Conditioner Logo
304 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
