Question about Nintendo DS Lite Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
I have read other posts, but after trying some steps, my DS is still dysfunctional. I noticed a strange thing, which makes me wonder exactly where the problem is located, but if I jam the upper lid far back, I used to be able to get it to turn on, only if the lid didn't move. After quite a few times of doing this, it stopped working at all, and only does the quick power on, power off problem that many people have. I have checked every connector I could access, and checked the wring. All seems fine. I would gladly appreciate any help. Thanks.
  • 2 more comments
  • Anonymous May 23, 2008
    The problem is the screen ribbon. Once you disassemble, good luck trying to make it functunal again. Very frustrating
  • Anonymous May 29, 2008
    I have the exact same problem. I can't keep my DS on long enough to get a screen go to the white menu. Just as Nicane said, the screen flashes and then dead. Even if i leave the DS flat on a table and turn it on and don't move/touch it, still just turns off.
  • linda07kay Aug 04, 2008
    DS HAS NEVER BEEN APART YET WHEN I TURN IT ON THE GREEN LIGHT LIGHTS UP BUT NOTHING ON EITHER SCREEN NOTHING HAPPENS AT ALL WHEN ITS SWITCHED ON CAN ANYONE HELP
  • Anonymous Nov 26, 2008
    My DS works but the top screen is all blurry and my top part is moving around and would not stay in one place.
If you have taken the ds part then when you have put it back together u may not have pushed the ribbons back in its slot enough even tho it may seem you have try this it shud work if not then u have blown the r1 and r2 fuses
Posted on Aug 03, 2008
Hi just bought a replacement screen for my ds and had the same problem. Ds powers on, screen flashes and turns off. Anyways googled the problem and found your posts. Went back to my ds and looked closer, when plugging the screen connector in make sure it is completely flush with the clasp, i might look ok but its not, push it in further. THaNKS GUYS
Posted on Jul 02, 2008
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
Posted on May 29, 2008
After replacing screen there is a grayish look during light hours
you replaced the inside LCD screen?
i guess there is a full story here, but...?????
light hours,?
you mean with windows open and the screen goes gray?
some monitors and tv's do that, now. called GREEN MODE.
turn it off. My stupid TV (LG) goes gray with a reading lamp on.
silly to the extreme that. Im sure yours is not with a room light sensor, but do RTM.
as you know , the screen is black lighted.
and old screens (2005 it is) do get gray and other effects.
my old view sonic, (now on server duty, off mostly)
has dim and yellow back lamps.and the LCD has age effects.
this is all 100% normal for 8 years, full time service,
in fact lucky it works at all. truth being.
elaborate what you see better may be we can hone in on the reasons. and the what you touched inside.
Oct 03, 2013 | Samsung SyncMaster 940BF (Black) 19" LCD...
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Woods In-wall Timer Heavy Duty, Model #59018 -- I just installed my timer and was able program and set the time, but when I push the manual override button to turn the light on, the light flashes and turns...
Quick answer:
1) Programming steps say 'press clock key to return to current time and day'
2) Use mode button and change between AUTO & RND >> try manual override in each mode
3) Does timer turn lights on-and-off with program, or do they blink too?
4) Swap Black and Red wires
5) Try timer on light in different room, on different circuit breaker
6) Timer might be defective
Longer answer:
Woods 59018 manual does not show troubleshooting steps except 'check wiring; switch Red and Black leads; and/or reset programming'
Seems unlikely you could program timer unless timer is wired correctly ... unless there is a short of some kind.
To review wiring.
Green goes to bare ground wire.
White goes to Neutral white wire (neutral is usually 2 or 3 white wires twisted together and shoved to back of box)
Black must connect to Hot from circuit breaker
Red must connect to Load (light, fan, motor etc)
How to test wiring
Disconnect timer and set aside.
Mark each wire
Separate wires in box so they don't touch
Use ordinary tester (you can tape tester leads to wood sticks)
Turn on power
You should have two black wires that were originally connected to switch
Test black wires to bare ground > when tester lights up, that is the Hot wire.
The other black wire goes to Load
Now you want to find the neutral.
Test the Hot black wire to white wires in box.
When tester lights up, that is neutral.
If everything checks out, I guess timer is defective.
Sep 29, 2010 | Woods InWall 7 Day Digital Programmable...
When you turn on the ds the green light comes on, the top screen flashes white and the the green light goes out
This is because your bottom LCD screen is faulty. You can buy these quite cheaply off of ebay for around £10 and they are pretty easy to fit. There are lots of guides out there but if you need any more help please post a reply to me here.
Thank you for using FixYa
Aug 15, 2010 | Video Game Consoles & Games
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
DS Not turning on - both screens flash
Try this if you haven't yet.Take the battery out,read the voltage with a meter,If low your charger is not working.Also if no meter try reinstall batery.Good Luck. DS's are unpredictable,you could not touch it for another month and it will work.
Sep 05, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
DS Lite: Green light, touch screen flashes white and turns off problem.
i had the exact same problem, i just fixed it a minute ago by pushing the ribbon cable in farther. make sure you push on both sides of it with your fingernails until it goes all the way in then latch it down.
Feb 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
561 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
