Question about Zebra Z4Mplus Label Printer
Ribbon wrinkles when printing barcodes
We are having a problem with the ribbon wrinkling and leaving blanks on our barcodes as the labels are printed. We have this on two printer one worse than the other and it happens on just about every label.
Thanks
  • fgonzalez Aug 01, 2008
    I have the same problem with one Zebra 4M Plus.
  • John Feb 29, 2012
    This is caused by incorrect pressure settings. Try adjusting the knobs on the top of the printhead so it applys pressure evenly. You may need to replace your platen roller (the rubber roller under the printhead). Run your finger along it and test for uneveness. Or just replace it, the're cheap ~$30.
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
Posted on Aug 15, 2008
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
We are getting white vertical lines running through our barcode label. it looks like printer ribbon is wrinkling when printing them on long runs. How can we stop this
When you have this problem you need to determine if the ribbon is wrinkling before or after the head. If it is before the head then you need to adjust the bar prior to the head. There should be a phillips head screw there and directly behind it there is an adjustment. Loosen the screw and then move the bar (it is slightly arc'd) so it smooths out the ribbon. This is the least likely suspect. Most likely the head is not square. If the head is not square with the roller below it will cause the ribbon to "dance" as I call it. It will slowly move over then jump back to its rightful position. Or it could just wrinkle. If this is the case and your print looks good then you can adjust the ribbon bar right where the ribbon comes out of the head. There are two screws at the top. Loosen both of them and this adjustment bar will slide all the way back. Once this goes back. Manually manupulate it until it smooths out the ribbon. Once you manually figure out where it is smooth then tighten the screws back up. Feed a few labels and see if the ribbon is smooth.
Jan 27, 2011 | Datamax I-4208 Thermal Label Printer
Constant wrinkle in the print. tried different
Usually a ribbon wrinkle is caused by an imbalance across the printhead. There is more pressure on one side of the ribbon then the other (if using a ribbon across the whole web). Check the printhead pressure adjustment dials located on top of the printhead. One side may be "down" more then the other.
Hope that helps !
Apr 05, 2010 | Zebra S4M Thermal Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
466 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
