HPvs17e monitor will not power up
My monitor went black and will not come back on checked pwr cord(okay) checked fuse(good) but noticed that quite a few capasitors have a white substance around them not sure if it's glue or the capsitors are shot? tried to locate another complete power controller can not find one anywhere CAN YOU HELP?????????????????
  • raeinama Jun 21, 2008
    I have the same problem. my monitor doesn't work, just out of the blue. I tried all power supply and cords.
  • Alfred_Riggs Sep 14, 2008
    Yup, sounds like exactly the same problem, the blue power light appears for a fraction of a second and nothing, was working fine yesterday with no signs of any problem.
    The solution sounds technical, and not something that I would be able to do myself without guided instruction... is there a hyperlink with futher information that may be of help?
    Regards, Alfred.
  • 101 Answers
Hi the SMPS needs to be checked - some of the failure prone comps., Bridge Rectifier and Power Transistor check them after disconnecting power completely , the large electrolytic Cap., will hold charge even after disconnecting the power so be very careful. The substance around caps., is epoxy so as not to let them explode in the event of short circuit
Posted on May 24, 2008
My monitor has gone a bright blue
Check the pins in the end of the monitor cable, look for bent ones. If it's okay re connect to the monitor and try again. Unplug the monitor and wait for a few seconds, plug power back in. Cycle power on the monitor. Then restart your computer. Wiggle the monitor cable on either end and see if the color changes.Good luck
Sep 30, 2012 | Microsoft 66I-00752 WINDOWS VISTA -...
We had a power outage at my shop and now my Dell e171fp monitor will not power up. No light near on button and monitor is black. Switched to known good pwr cable and monitor still blank.
This generally is not good news, when the power comes back on it peaks causing the damage in it's wake. The power supply has been compromised and if you are very lucky you might get away with a fuse change. The monitor will need to be dis-assembled to assess the situation and hopefully it will start back up with minimal repairs. The fuse should be located near the power cord going into the circuit board.
Feb 28, 2011 | Dell E171FP 17" Flat Panel LCD Monitor
Not working
it could be possible that the pwr cord might have gone bad. change it .
before doing that try disconnecting the pwr cord from the back of monitor and hold the pwr button for 30 sec. connect the pwr cord properly and then restart the comp. if this does not work then check with other pwr outlet. if this doesnot work then replace the monitor its a problem with the monitor and needs to be replaced// nothing is wrong with the computer//
May 07, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
With my hpvs17e power goes on then a black screen why does that
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
When plugged into power I get no green light at the pwr switch, All is black. Is there a fuse burned out or is the pwr. switch broken???
1. Try a different power cable.
2. Open the monitor up, see that the soldering to the cable connect, or the switch isn't broken.
Jun 22, 2009 | Dell SE198WFP LCD Monitor
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Mag LT776S Monitor (Screen turns black)
This is not quite clear. You say no image at home or at school but worked at the store Did you see it working at the store? Check the cord sonnector for bent pins and or replace the cord- then come back
May 16, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
