Question about Dual Handset Cordless Telephone with Caller ID TRU-8860/2 (TRU88602)
RED INDICATOR LIGHTS FLASING ON INTERCOM
KX-T3250
  • wiredup Oct 30, 2008
    My red intercom light is fahing too! Drives me crazy!!
    Novelist:
  • 106 Answers
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
Posted on Mar 23, 2009
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Hi i m using th Panasonic KX-T7730 Phone. The light (RED)on top of the instrumernt is lighten always. Why??/If i press the button PROGRAM is asks for some PITS code or something. Can u pls clarify why???
the light is lit red because you have a message (it is the message waiting light)
if you want to get rid of the light, try either INTERCOM *700 then your extension number, or INTERCOM 700 your extension number
as for programming, if you press program, it wants to know what you want to do, so it asks you which feature you would like to program in the form of a 3 digit number
Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Carl
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
I am tring to figure out how to program extensions on our kx-t7737 phone.
A 773x phone has 24 buttons, 12 are lighted and 12 are Feature. If you want to reassign some of the lighted buttons as extension buttons on the phone, you can press PROGRAM 1 + ext no STORE and that will give you a busy indication whenever that extension is off hook.
You can program the right side buttons to speed dial the extensions by just pressing PROGRAM ext no STORE. It will dial the extension when you press it if you have intercom dial tone.
How the button behaves is dependent on which system the phone is attached to. In a TA, you have to start with dial tone on the intercom. In a TAW/TDA you don't.
Carl
Sep 28, 2009 | Panasonic KX-T7633 Corded Phone
WE HAVE RCA EXECUTIVE SERIES PHONES INTERCOM LIGHT FLASING
RCA Executive Series Phone: How do you place the caller on hold and then intercom to another, then transfer?
Mar 17, 2009 | Lands Phones
Can you tell me how to get out of SP-PHONE which has a red light
Under my Intercom light I have a green light (7731,7735). I'm not sure why yours is red, but here are a couple of things to try.
Press "1" on the keypad without picking up the handset. That turns off Background music and the display will say BGM On or Off.
Press Intercom or pick up the handset and dial 790. That's the extension reset code.
If neither one of these work, post back with the model number of the phone system cabinet the phones are plugged into. It's probably a Panasonic TA-624/824 but there's a chance yours is different.
Carl
Mar 02, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
Can I do anything about it?
Nov 08, 2008 | Panasonic KX-TG2357 Cordless Phone
Dual Handset Cordless Telephone with Caller ID TRU-8860/2 (TRU88602) Logo
922 people viewed this question
Top Dual Lands Phones Experts
Are you a Dual Lands Phone Expert? Answer questions, earn points and help others
