Question about Canon FAXPHONE L80 Laser
Phone calls get cut off and fax goes into recieve mode
Sometimes during calls the caller gets cut off and the fax goes into recieve mode. This can happen at the start of a call or happen after the call has been going for 5 or 10 mins.
  • Anonymous Mar 19, 2014
    ON SOME NOT ALL CALLS FAX NOISE WILL SOUND CUT OFF PHONE
    Sniper:
  • 57 Answers
If you are using the fax as both for calls and receiving faxes make sure you have the fax set up to FAX/TEL mode. This should solve your problem.
Posted on Jun 24, 2008
Canon mx 410 fax answers voice calls
I have an MX870 with the same problem - fax picks up during a voice call and I can no longer hear the caller. As with everyone else, the problem is intermittent and not replicable.
I have tried tel priority mode and fax priority mode (from the phone/paper submenu under physical Fax button) and all the various RX receive setting under Fax Settings submenu of the physical Settings button.
But I have a new possible solution. I only use the fax for outgoing -- for some time now I have been using K7.net for incoming faxes which delivers faxes to my email. That way I have a dedicated fax number, never miss an incoming fax while on the phone, and I have all faxes in electronic form as well.
So, my new idea was to set the MX870 to DRPD (distinctive ring pattern) receive mode (from the phone/paper submenu under physical Fax button). Since my phone service through Xfinity/Comcast does not offer DRPD, I am hoping that the MX870 will NEVER pick up a fax.
I will keep you posted as to whether this works.
Jan 13, 2012 | Canon Pixma MX410 All-In-One Printer
Cannot recieve faxes but i can send them
It is set on "manual receive" rather then "automatic receive"....check your "reception mode" settings and set it properly
Jul 16, 2009 | Pitney Bowes 9920 Plain Paper Fax
BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
All In One
Depends of how many lines yoou have. Ask to your phone company. Usually there is a number sequence code that you have to type on the phone keyboard to know which is that phone line number
Oct 07, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
Phone line goes to fax, then ans mach...now caller ID won't work.
Set the reception mode to Fax with answer machine TAD. Make sure its set for fax with answer machine.
May 29, 2008 | Brother IntelliFax-2820 Laser Fax
All calls go directly to fax. Calls don't go to answering machine. I can't answer calls manually to speak with caller.
You seem to have chosen the correct answering mode which is ans/fax.Also pls check whether DRPD mode is correctly set .
It should be off in case your tel line does not have dual ring feature.
happy faxing
omnipresent
Oct 16, 2007 | Office Equipment & Supplies
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Canon FAXPHONE L80 Laser Logo
87 people viewed this question
old marine
old marine
