Question about Whirlpool LSR7333 Top Load Washer
Water Draining off Automatically
I have a whirlpool semi automatic washing machine. While filing the water in the tub, the water drains off even when the drain selector is put on WASH/RINSE
  • 5,911 Answers
Sounds like you have a siphoning problem. Click on the following link for instructions on how to determine if this is the case:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If this is not the problem, or if you need further advice, please post back and let me know. I hope this helps you.
Posted on May 22, 2008
Why is water automatically draining as it is filling?
There is most likely a leak with water getting into the cabinet of the washer activating the anti flood switch which in turn drains all water out to stop flooding check for damaged door boot
Dec 21, 2014 | Kenmore Washing Machines
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Indesit 657w
CHECK TO SEE IF THE DRAIN HOSE IS RAISED ABOVE THE REQUIRED HEIGHT. IF THE WATER IS OVER FLOWING THE TUB THEN IT IS USUALLY THE A BLOCKAGE IN THE PRESSURE SWITCH HOSE, OR SOME INABILITY OF THE WATER LEVEL SWITCH TO MEASURE THE AMOUNT OF WATER IN THE TUB.
Dec 23, 2013 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Water come out backside automatically
Hi parag vyas - This is not a normal location for the water to be leaking and often it is because the water is leaking out of the rear tub. More than likely, the unit is not draining properly or a damage tub. Therefore, as the tub spins, the centrifugal force is driving the water up the sides of the tub. At this point, I personally recommend consulting a certified technician for an accurate diagnosis and to assist with the repair(s).
Jun 09, 2013 | Electrolux Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is draining out the bottom as soon as it
A HOSE CAME OFF--THE DRAIN HOSE HAS A CRACK IN IT-- THE OUTER TUB IS PLASTIC SO IT COULD HAVE A HOLE IN IT---THE DRAIN PUMP IS LOCATED FRONT BOTTOM OF YOUR MACHINE IT COULD HAVE WORN A HOLE IN IT (PLASTIC ALSO)
Oct 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LSR7333 Top Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
