Question about PSB Image Sub Sonic 6i Subwoofer
PSB Subsonic 6i
Sub just quit. The light does not come on. I changed the fuse but still nothing. Any ideas?
Thanks
  • 1 more comment
  • jduncan85 Aug 31, 2008
    I have the same problem with the PSB SubSonic 6i Subwoofer
  • Anonymous Mar 02, 2009
    Im having the same problem with subsonic 7
  • atomboer965 May 18, 2009
    I have the same problem with the PSB Subsonic 5i subwoofer.
    Problem Solver:
  • 5 Answers
Check the power cable.
Posted on May 24, 2008
I have a PSB subwoofer 6i and the fuse keeps blowing every time it is renewed.
I have two in my shop right now. The power supply is to blame with these two. the manuf. has used some type of epoxy to hold down components before wave solder. This is in the high volt side of the switch mode power section right on top of the bias components . This epoxy breaks down and becomes resistive to the components below causing a direct short. There was a company years ago that had this problem with the same epoxy. A real stupid move then and a real stupid move now. If your power board is burned due to this problem your unit may not be able to be serviced. Solution is to change the supply. Of course the supply is 3/4 the cost of a new sub. Another real stupid move.
This opinion was provide by THE GREAT OZ.
Mar 29, 2011 | PSB Image Sub Sonic 6i Subwoofer
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
I need an owners manual replacement...lost the manual during a move and need to hook it back up.
the user manual for this speaker is not avail on line for download, but u can request a copy from PSB SPEAKERS at the web link below by email.
http://www.psbspeakers.com/contact
You can also call them at:
Tel: (905) 831-6555 • Fax: (905) 837-6357
Jun 04, 2010 | PSB Stratus Subsonic 7 Subwoofer
Humming noise when woofer turned on
check the NPN and PNP transistor output maybe shorted.....
Jul 07, 2009 | PSB Image Sub Sonic 6i Subwoofer
What does sub sonic mean on my Kicker kx1200.1 amp? Do it need to be off or on?
Subsonic refers to frequencies too low for the human ear to hear. Generally humans can hear frequencies in the range of 20 to 20000 hertz (cycles per second), but we hear best in the range of 1000 to 4000 hertz. High amplitude subsonic frequencies can cause damage to your speakers so many amplifiers have an electronic filter in them to reduce the amplitude of these very low frequency signals.
May 21, 2009 | Kicker KX1200.1 Car Audio Amplifier
What should the subsonic filter be at
The subsonic filter is to help your system's overall performance by blocking frequencies that your subwoofer cannot effectively produce. For example, if you have a single 10 inch sub, it's not likely to be able to produce sound much lower than 60-80Hz with any respectable volume. If you have the subsonic filter on and set to 60Hz, it will prevent a 40Hz tone from being delivered to the sub. If the subsonic filter is turned off, your sub will get everything, and it will try to produce every sound. If it gets a 40Hz tone, it will make the sub work extra hard without any audible noise. It'll just degrade the overall so the answer to "shoud the subsonic filter stay off" would be "it depends on your system" but in most cases, you should keep it on, and set it to the low end of your subwoofer or woofer range. This also applies to filters on mids and highs.
May 15, 2009 | Performance Teknique ICBM-2400 Digital...
No LED light on PSB Alpha Subzero-i and keeps blowing fuses.
Others have had similar problems with the amp on this model. There is probably a circuit design error which causes some components to blow and as far as I've read, fixing it (or replacing the fuse) won't make the problem go away for long. Try contacting PSB or the retailer.
Dec 02, 2007 | PSB Alpha Sub Zero Subwoofer
PSB Image Sub Sonic 6i Subwoofer Logo
813 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
