Question about Yamaha HTR-5840 Receiver
No sound all of the sudden when on dtv
I lost sound when on dtv/cable.
I also noticed that that position on display is also dim and the others are not dvd, vcr etc.
Can you help me?
Make sure input mode selector on the front is set to either analog or or digital. For example if the sound input from the dtv/cable is analog and you have it set to digital, you will get no sound. Change it to analog. This happens to me when using my crappy dvd/vhs player and I have a vhs playing (analog). Hope this helps...
Posted on Jun 13, 2008
Screen dims slightly suddenly
Hi.
Plasma display suddenly dimming down is usually symptom of a faulty sustain board. Sustain boards and other parts like the PSU must be tested before replacing any component.
Dec 12, 2011 | Panasonic TCP50S30 50 50 Plasma TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
When purchased, upon starting the car, the radio (manufacture model) volume knob would actually be turning down when you were turning the radio knob up, and it did the opposite if turning the knob up, the...
sounds like a serious electrical issue there hard to track down could be the computer staarting to go in car the radio could of been hooked up wrong causeing other stuff to short out what year is the car what kind of car
Dec 01, 2010 | Pontiac Grand Prix Cars & Trucks
NEC - Model NLT-32HDB2. The DTV (digital receiver) stops working after an hour of use - the television seems to have lost all trace of the DTV settings. The analogue and the other inputs (eg AV HDMI) are...
You can fix this, all that is needed is to carefully understanding the electronics parts used and having little of basic knowledge in electronics.
The problem is in either power supply or the Y sustain board. The Y sustain board is are relatively large board if out of which go connections to the side of the display , it therefore closer to either the left or the right side of the display , has at least one rather large heat sink on it and far power cables connecting it to the mains power supply .
Often there are fuses on that board , one or more , check them
If they are blown you can try to replace them, but expect them to blow again , usually the whole board needs to be replaced.
Often that need to be done in a service center as there are some adjustment to be made after replacement.
Aug 22, 2010 | NEC 19 in. LCD TV
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Display is extremely dim to where you almost can't read it anymore
take down the display and clean the contacts if that does not work replace it.good luck.
Apr 27, 2007 | Sharp R-360E Microwave Oven
Yamaha HTR-5840 Receiver Logo
128 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
