Question about Toshiba DKT-2010 Corded Phone
DKT's wont ring from transfer
I have a 424i with Stratagy DK 3.3 release. 990 answers- options press 1,2,or3 receive, please hold while i try that ext. DKT wont ring from transfer. I have programmed vm id codes and call forward 604. There is something I am missing in programming- plus no mess waiting lamps are working. Sorry been 5 years from last install.
  • Michael Bowen May 11, 2010
    Are you still having a problem ? If you are please repost so I can help. .....Mike
    Problem Solver:
  • 15 Answers
Put an "H" after the extension in the voicemail, i.e. 200H, you have to put in your #656 #657 codes into the phones to integrate the voicemail. #656 91, ext of voicemail pilot, hold #657 92, ext of voicemail pilot, speed dial button (program one on the phone if it doesnt already have it), enter the number of seconds before the phone should forward to voicemail, i generally do 16, hold. that should fix that!
Posted on Nov 22, 2008
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
How do you get rid of the beeping noise when you dial on a Toshiba Business Phone - Model #DKT3210-SD?
Dial Pad and Button Beeps
Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs.
1. Press 3+6+9+Hold(simultaneously).
2. Press 0.
3. Press Feature Button 1 (FB1) to toggle On/Off.
FB1, LED On: buttons beep.
FB1, LED Off: buttons do not beep.
4. Press hold to set the option.
5. You must also go off-hook, then on-hook to exit the program mode.
Mar 03, 2010 | Toshiba DKT 3010 Corded Phone
DKT 3010 SD programming mode?
If the phone is on any Toshiba DK system, enter programming mode my pressing the following sequence (without selecting an intercom line, or an outside line, but at the phone's idle state with the handset down) *#*#1*2*3
On a CIX or CTX System, again, at the phone's idle state w/ handset down dial *#*#1*2*3*
Jan 07, 2010 | Toshiba DKT3020SD Corded Phone
How do you set the number of rings?
Ring Select and Toll Saver
Use Ring Select to choose how many times
the line will ring before the system
answers a call. Set for 2, 4 or Toll Saver.
When you set the system for Toll Saver, it
answers after four rings when you have no
new messages, and after two rings when
you have new messages.
1 Press and hold S for about two
seconds. The system announces the
current ring selection.
2 Press and release or
until the system announces your ring
selection.
3 Press and release P to exit
— OR —
Press and release S to change the
Remote Access Code (follow Steps 2–5
under “Remote Access Code”).
Here is the manual:
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Nov 22, 2009 | AT&T 1717 Digital Answering Machine
Transferring call to my voicemail
DK system call forwarding in icm #604 for forward busy and no answer
Jun 19, 2009 | Toshiba DKT-2010 Corded Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Toshiba RPCI DI Station Ringer
which system?
The most popular is the DK system but it came in several revisions.
The primary differences are the way the ports are numbered and several program numbers.
Programming is done from port 005(ext 205).
The sequence of events is:
enter programming mode by pressing "speaker *#*#1*2*3"
enter ringing program
Day ring is "spkr 81 hold"
enter port number of the port you want to ring (example : 007#)
press buttons corresponding to the lines you want to ring then press hold.
To exit programming press"spkr ## hold then spkr ## hold.
Oct 17, 2008 | Toshiba DKT-2010H Corded Phone
Can not set no of rings on old sprint answer machine SP818 please help
Use Ring Select to choose how many times the line will ring before the
system answers a call. Set for 2, 4 or Toll Saver. When you set the
system for Toll Saver, it answers after four rings when you have no new
messages, and after two rings when you have new messages.
1. Press and hold [SET UP] for about two seconds. The system announces
the current ring selection.
2. Press and release [ANN/SKIP] or [MEMO/REPEAT] until the system
announces your ring selection.
3. Press and release [PLAY/STOP] to exit
-OR-
Press and release [SET UP] to change the Remote Access Code (follow
Steps 2-5 under "Remote Access Code").
Oct 01, 2008 | Lands Phones
Stratagy DK issues
The night key on the phone only changes the location the trunks or lines ring. The voicemail should be set up with 990 as an " Introduction ", Thank you for calling ABC Company and 991 is the " Instructions ", If you know your party's extension please enter it now. The mail boxes should match the extensions and ring the phone. you need to verify the extension field in each mailbox to make sure they match. Do you have access to the voicemail programming ?
May 22, 2008 | Toshiba DKT-2010 Corded Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Toshiba DKT-2010 Corded Phone Logo
228 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
