Question about HP Photosmart 2575 All-In-One InkJet Printer
Error Message 0x07674dd6 1895.lib_barracuda.c
This message appears in the read out after printer is turned on. What is going on?
  • 1 more comment
  • Anonymous Jun 18, 2008
    I just found the same error message here (who in the world tags and error as "barracuda?!). I tried the recommended solution and got a message about there being a problem with the ink cartridges. I slid the cartridge holder over to the loading position (it wouldn't go by itself), pulled out both ink cartidges and carefully loaded them back in after checking to make sure there was nothing wrong with them (they are brand new). The printer confirmed their installation and said to load the paper. I loadeed the paper and it said it was going to allign and started running before stopping and throwing out a new error message: Error:0x805d1409 4426:fm_keywords_cm.c
  • jcpacio_1110 Feb 05, 2009
    i have the same problem.Error Message 0x07674dd6 1895.lib_barracuda.c appears on my printer's screen whenever i turn on it on and my computer cannot read it, thus i can't install it.. i have tried the recommended solution but it doesn't seem to work.. hope there's something i can do..thanx
  • Anonymous May 03, 2009
    i've the same problem
First excuse my bad chool'english ;
I have the same problem. No body have a soluce for me but.... I have changing the power cable and that resolve the problem ! Then i loocking beter my cable and one of the three was broked. I repare them and now the photosmart works good with this cable to !
The error 0x07674dd6 => Power cable troubleshot. !
Have a goed day !
En Français.... J'ai eu le même problème. L'aide Hp en ligne ne connais pas ce message d'erreur et me disais de faire réparer l'imprimante. En démontant celle ci, je me suis aperçu que le cable d'alimentation était endommagé (un des trois fils était sectionné). J'ai reconnecté le cable coupé (une simple torsade). Et hop, le message d'erreur avait disparu. Tout fonctionne de nouveau tres bien. En fait, c'est le fil d'alimentation moteur qui est indépendant de l'alimentation générale de la machine.
donc erreu 076074dd6 => Vérifiez votre cable d'alimentation ! (le barracouda étant le système d'etrainement du support cartouche et appel papier)
Bonne journée
Posted on Feb 16, 2009
  • carmen Aug 11, 2012
    Thank you veeeeery much. We found out after your response. Merci beaucoup nous avons trouvee apres votre reponse. Our cat has cut the cable e manger un part. Merci e a bientot
We had the same problem and this solution fixed it.
Thanks.
Posted on Sep 12, 2008
Unplug the printer, hold the OK and Cancel buttons, and plug it back in. That should reset it.
Posted on Jun 06, 2008
4 Suggested Answers
SOURCE: Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Posted on Nov 07, 2007
SOURCE: printer displaying 49.2F80 error message
Network data corrupted or print job corrupted
Posted on Mar 09, 2007
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
Turn on printer and light continues to flash. Not
What the flashing light means
The Power light can flash for several reasons:
• The printer cover is open.
• The printer is out of paper.
• A problem exists with the printer, such as a paper jam or a problem with a print cartridge.
If an error message appears
Read the error message that explains the problem and its solution.
If no error message appears
Check the status of the printer by using the printer tools. To gain access to the tools, open the Printer Properties dialog box, click the Services tab, and then click the Service this device button.
Use the printer tools to perform the following tasks:
• View estimated ink levels.
• Clean the print cartridges.
• Calibrate the printer.
• Print a test page.
• Perform other functions as needed.
Jul 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Mar 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
5,059 people viewed this question
Ben Johnson
