Question about Toshiba CX36F84 TV
36"toshiba tv perfect picture , no sound
    Sergeant:
    Champion:
  • 318 Answers
Sound is produced by so many components, but i will mention criticle ones. take your tv to w/shop
and let them check the following
speaker continuity resistance
capacitor coupling ( electrolitic) feeding a speaker
final amplifier IC
Vcc voltage feeding the IC
or a jack which seperates speaker and external sound. im positive it will work
Posted on Apr 16, 2009
My Toshiba 36" CRT TV has no sound any ideas?
Check its speaker and audio output section circuits for the fault
Sep 07, 2012 | Toshiba CF36G55 36" TV
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
No Sound, Picture is perfect
Check if there is a speaker switch somewhere, back of set or in a menu.
Nov 03, 2007 | Toshiba 36A43 36" TV
Power but no picture on a toshiba 36a61 36" tv
could it be the socket wirings was loose check and retightened. more help....dnlsabangan@yahoo.com
Nov 09, 2006 | Toshiba 36A61 36" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
