Question about Olympus Camedia C-60 Zoom Digital Camera
Lens retracting but won't stay open
When I slide the lens barrier open, the lens will come out, but won't stay out. The green light flashes as if it would still operate if it weren't for the lens issue. Can I fix this myself, or is it a quick fix for a professional?
The slider is held in its groove by a plastic liner and part of mine wore away with the upshot that when I slid it open, the tiny pin on the slider dropped back a little way. We are only talking a tiny amount here but it was enough to activate the switch to reclose the lens so the thing was sliding in and out of its own accord as I rocked the slider.
I simply superglued in a tiny piece of plastic in where the worn away bit was and it cured it!
Chris, England
Posted on Jul 14, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey kbwilson,
This could be a quick fix for an authorized service technician, but it could also be damage to the lens and the only way to know is to have it looked at by an authorized service technician. A common cause of this problem is some kind of obstruction in the lens movement (i.e. sand in the lens), which should be able to be remedied by a cleaning of the lens by a technician. I would not attempt fixing the camera yourself because you could end up doing more harm than good.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 22, 2008
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
Lens wont retract with or without new batteries. green light blinks but no lens movemant even using wide/tele buttons
Since you already used new batteries and still lens will not moved and you can just see flashing green it means that the Gar of the camera is defective You may call repair center specialize with kodak camera's at 1 800 665 6515
Nov 09, 2009 | Kodak EasyShare C340 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Lens won't retract
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 21, 2008 | Canon PowerShot A430 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Lens won't come out
It sounds like the sensor that tells the camera weather the cover is open or closed has failed or come loose. This is a fairly common issue on cameras with the sliding lens covers. Our shop would charge around $50 in labor to fix this issue if it is that sensor. If a part was required it would be somewhere between $20 and $50 depending on what Olympus charges for the part. Cannot speak to what other shops may charge. David Millier Advance Camera Repair
Feb 22, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Olympus Camedia C-60 Zoom Digital Camera Logo
104 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
