Question about Sharp AR-M237 Digital Copier
Sharp copier sf 2530 developer reqired error code (ie indicator on)
Please help to reset "developer required" error code and Blank prints on sharp sf 2530 (analog) I used code 42 sub code 01 after replacement of developer and tonner. this did not work
  • dankap May 23, 2008
    Hi, additional info on the above problem. it seems at every replacement of developer and drum ,on a sharp sf2530 copier, a # of maxmum prints the machine should reach should be reset. If so then help with codes to reset the drum and the deveoper counters.
    trusting & thanking U in anticipation of your help!!
    Dankap
  • 4 Answers
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Posted on May 30, 2008
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp SD-3062 error code F2 00
F2-00, ID pattern reading error.
For some reason and it may just require cleaning and recalibration, but the IMAGE DENSITY pattern is not being read properly.
It may need new developer, the drum may need to be.replaced.
First and foremost it should be cleaned, Optics coronas and machine cavity.
Hope this is of some help.
Ed
May 21, 2009 | Sharp SF 2020 Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Jan 24, 2008 | Sharp AR-5320 Black and White Copier
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Digital Copier Logo
817 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
