Question about D-Link AirPlus G DWL-G122 (DHDWLG122) 802.11g/b Wireless Adapter
How to fix my d-link wireless usb?
My wireless usb was reading before and now it doesn't. It says that it does not recognize the usb or it has malfunctioned. How can I repair my own wireless usb to work.. sometimes it works and sometimes it doesn't.
  • 2 more comments
  • Anonymous Jun 27, 2008
    omfg i have the EXACT same problem and its pissing me right off, HELP ANYONE
  • Anonymous Jul 01, 2008
    got the same problem. who should fix the problem microsoft or dlink? finger point time .....
  • Anonymous Aug 22, 2008
    i Have same problem
  • Anonymous May 20, 2009
    my one just doesent work and flashes randomly
    Problem Solver:
  • 6 Answers
1. check if you have the latest network adapter driver. you can download it at the manufacturer's website.
2. USB port may be loose or unstable. you may need to have your PC serviced for that.
3. USB adapter itself may be worn out already. you may need to replace it.
Posted on Jan 25, 2009
Open the router and you will see that there is no contact with the usb conector and the main "brain" of the adapter so all you can do is try and join it back together.
Posted on Sep 08, 2009
I got the same prob
Posted on Jun 27, 2008
Usb modem lights up but mac doesn't recognize
I had the same problem I have a ZTE USB modem & when I connect it with mac it never show up...so I googled ZTE for Mac & I found a driver update & update for connection manager . After installing them the modem work as charm
Jan 25, 2013 | Computers & Internet
Window 7 doesn't recognize birdcam
after plugging in the USB cable to the camera and computer you need to set the mode button on the camera to "setup". Then the USB will be recognized and you'll be able to see your drive and pictures. I had the same problem then went and re-read the instruction manual... when in doubt... READ :)
Dec 13, 2012 | Wingscapes WSCA03 Audubon BirdCam Bird...
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
Doesn't recognize usb wireless adapter
have you installed the driver? is it usb or internal? theres not alot to go on there
Nov 19, 2011 | HP Compaq Presario v3000z Notebook
Iphone not recognized when attached with usb connnection
Try using different usb ports on your computer. If it doesn't work then try hooking up your iphone to another computer. If it still isn't being recognized then try a different IPHONE USB cable.
If your Iphone still can't be recognized after all of this then read the article at the link below.
http://support.apple.com/kb/TS1538
Also try restoring your iphone to factory defaults if necessary. This is a last resort. If your iphone still won't get recognized by the computer then it could be the connection on the Iphone is defective and in that case replacing the phone is the only option.
Nov 03, 2011 | Sony VAIO VGN-N325E Notebook
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
I got a Belkin wireless usb adapter (F7D4101) and when I put the CD in my driver, the CD is not recognized what so ever in the D drive. However, the USB adapter is recognized when I plug it in, but when it...
If the cd does not work on your computer, you might want to download your softwares and driver from this LINK as an alternative.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 14, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
My computer doesn't recognize my wireless card. Driver install didn't help.
D-Link AirPlus G DWL-G630 Wireless Cardbus Adapter 6.0.1.1 ... Intel Next Gen Wireless Wi Fi Link 4965AGN card suitable f ... I uninstalled mine and my computer did not find it and thus did not update it any suggestions? ... I m in Brazil and HP doesn t give any assistance for this model Do you know ...
www.soft32.com/download_179407.html - United States
Jul 02, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link AirPlus G DWL-G122 (DHDWLG122) 802.11g/b Wireless Adapter Logo
938 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
