Question about Canon CanoScan LiDE 25 Flatbed Scanner
Your post for CanoScan LiDE 25
Can you please elaborate a little?
Is Toolbox installed?
Open Toolbox and click the 'Settings' button.
There should be a drop-down menu for 'Select Scanner'.
Does the CanoScan LiDE 25 show up in the dropdown?
So where were you attempting to scan from?
Any additional details would be helpful.
  • Anonymous Nov 16, 2008
    "Twain source not found" sucks seems lika alot of people have this issue.. Running XP. Driver seems to work there is self diagnose test in the driver properties. It runs the scanner bed and reports that the scanner i working OK..
  • mh_ajmalkhan Nov 22, 2008
    poda loosu
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
Posted on May 22, 2008
I lost my canoscan lide 20 installation cd
From this official link you can choose your operating system (windows XP, Vista, Windows 7), your language and download the latest version of drivers/toolbox for your scanner.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer, including your operating system and prefered language.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 16, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
Feb 27, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan 20
I had the same problem..the way to get around this is to open the toolbox and click "Save" instead of "Scan" After you do this you just create a file name and save it into a folder..also make sure you change the "save as type" to JPEG
Dec 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan Lide 25 scanner
Install CanoScan Lide 25 scanner via internet; lost CD installer
just want to know how can i install my scanner, i lost my cd i can't use my scanner since i bought this last july 2008. please help me to find the site to download the program of installing my scannerInstall CanoScan Lide 25 scanner via internet;
Thanks very much
Nono Setijono
Nov 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Installation CD lost
The driver and the CanoScan Toolbox can be downloaded. Unfortunately, the bundled software is not available for download. Try contacting the Canon Support Center to see if they can send you another.
May 06, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Lock Switch and IF cable
Mine was doing the same thing. When I get on the program, before I click "acquire" to preview and scan, I click OFF the toolbox and then everything seems to be okay and I can go ahead and scan.
Nov 27, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
I'm using a CanoScan LiDE 60 and I have no idea even how to begin. I need to scan in 5 different documents with numerous pages and I was hoping to create a pdf for each. Can you help me get started?
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
Nov 20, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
1,031 people viewed this question
old marine
old marine
