Question about Panasonic Workio DP-1820E Copier
Error E02-01 A loud clicking noise from time to time... Although getting more frequent at the moment.. Any ideas?
    Sergeant:
  • 284 Answers
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Posted on Sep 30, 2008
    Problem Solver:
  • 9 Answers
Tanks :)
Posted on Nov 24, 2009
I have a Canon MP630. It is making a horrendous noise, like cogs scraping, very loud. Error message Service Error 5C00. Any ideas?
I have the same problem & it's driving me nuts! Can anyone help with this or is it a throw away job?
Dec 19, 2010 | Office Equipment & Supplies
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
LOUD NOISE
Hard to tell without hearing it. But, if it is doing it all the time it is turned on but not in use most of the time that would be a fan making the noise. The other suspect would be a fault toner cartridge or the fuser. you may need to have a tech look at this.
Hope that helps...
Jun 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Manuals parts listing
hi,
Here are the manual links it will solve all your problems..
Click on the first and second
first
Second
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download it if u don't have..
Goodluck,
Don't forget to arte me as fixya..
Feb 01, 2008 | Epson DFX-9000 Matrix Printer
Loud grinding noise Toshiba 1550
It is one of three problems,
1- the developper is starting to go bad, unfortunately with toshiba it is a common problem the seals go bad in the unit the gears are very hard to turn giving a loud grinding noise, although you can rebuild the unit by changing the seals, it's VERY messy and they don't always work ( after spending all that time cleaning and changing the seals and gears and it didn't work, I just started to change the DV unit.) Test by taking out and turning the gear by hand, if you need a plier to turn it, it's bad.
2-the toner itself is a problem, take out the toner and look at wherre it sits there is a gear that turns the toner to feed it in the machine, if it's dirty and has toner it will make noise, test by taking out toner and close machine, does it make the noise without it?
3- cleaning section where the drum is, this is what turns to feed excess toner into the small pastic container, aggravating but not a mechanical problem. And also check the fuser ( where it gets hot)
I think I've covered everything for that machine.
Good luck
Nov 30, 2007 | Office Equipment & Supplies
Panasonic Workio DP-1820E Copier Logo
1,026 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
