Question about Fujitsu fi-5120C
Fujitsu Error Dear Sir, Am sankar from chennai We are facing the problem daily.. Am mention the error below.. "The Image scanner cannot be found. Please check power supply, cable connection, and the scanner is not used by other apps (Code: DS42019)." Pls give me solution for us.. It will very helpfull to us.. Give me an solution in this mail id rajashankaran.slm@gmail.com..
  • Anonymous Oct 10, 2008
    a new cable will not solve the issue
    Genius:
  • 1,224 Answers
Try a new paralel or usb cable you might have gotten a defective cable
Posted on May 26, 2008
Unable to Scan to print
As from your question it is understood that, you have not correctly uninstalled all the software and drivers related to Fujitsu Scansnap S1500M printer from the computer. So to help you uninstall it correctly and reinstall it again, please follow the step-by-step instructions mention under 'Uninstalling on a Windows OS' on page.no.355. and to reinstall it follow the instructions mention under 'Installing Scansnap Manager on Windows' on page.no.47 from the user manual link given below:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/s1500_s1500m_ops-guide.pdf
If issue persists, you are advised to contact printer manufacturer from the below link:
http://www.fujitsu.com/global/support/
GuruAid.com
Mar 16, 2016 | Fujitsu ScanSnap S1500M
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes....
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Apr 28, 2010 | Canon DR-5010C Scanner
Fujitsu fi5650 hispeed duplex scanner
Check the following items:
1 Does the document satisfy the paper specification?
2 Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
3 Replace the Pick roller and the Brake roller and see if the error is resolved. Check the consumable counter in the software operation panel or in the built-in Maintenance mode. When the counter exceeds the values, replace the Pick roller or the Brake roller.
4 Are the cables between the Control PCA and the Feed motor damaged? Are the connectors connected properly?
5 Is the Optical unit ADF installed correctly?
6 Is the Belt ADF installed correctly?
7 Is the Belt ADF damaged?
8 Replace Feed motor and see if the error is resolved.
9 Replace the Optical unit ADF and see if the error is resolved.
10 Replace the ADF unit and see if the error is resolved.
Pls acknowledge of the issue is resolved.
Regards,
Tech Satya
Aug 06, 2009 | Fujitsu fi-5650C
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Fujitsu fi-5120C Logo
1,743 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
