Question about Xerox Office Equipment & Supplies
Dirty printing job
I use a Phaser 3450N. I have faint vertical lines running through the printed sheet. Can I use a cleaning sheet in this model printer?
    President:
  • 2,072 Answers
Are they lines from one edge to the other in a straight line. Or is it faint reprint across the page?
Thin lines would most likely be a bad drum or cleaning blade.
If it is faint reprint it is the heat roller in the fuser.
Posted on May 25, 2008
  • Rick Kasper May 25, 2008
    I was going to ask you what you were printing . Your title turned out Dirty Printing job. hahaha. Found that humorous.
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Why xerox phaser 6360dn is printing only pink
Anonymous, Have you tried to print the test print, is that Pink?
Have you tried too print the configuration sheet, is that Pink?
Have you tried to run purge sheets are they Pink?
If the answer is yes to all the above then has the printer been moves whilst still hot or warm, you could have mixed the colours.
If all the colours were mixed together then you would have a dark dirty Brown. Further investigation needed.
Good Luck.
Sep 05, 2014 | Xerox Phaser 6360 Laser Printer
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Mar 25, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Sharp copier, not producing clean copies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
Mar 24, 2010 | Sharp Office Equipment & Supplies
I have not used my Phaser 6110 for about 3 months, and now print quality is bad. It appears to be only the black that is affected. print quality is faint although slightly darker down one side. I have...
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
Nov 24, 2009 | Xerox Phaser 6110 Laser Printer
4 faint lines running vertically down the sheets of paper
just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
Sep 09, 2009 | Samsung ML 2010 Laser Printer
How to fix ink lines running vertically on sheet
The system needs to either be cleaned or calibrated. The print heads can be cleaned with rubbing alcohol and cotton swab. To calibrate, you may have to look in the manual for maintenance or calibration settings.
Jun 30, 2009 | HP 640 Inkjet Fax Machine
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
364 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
