Question about RCA 25205RE1 Phone
Defaults to Line 2
When I plug the phone line into the socket marked 1+2 it defaults to line 2. Hence when I plug the 2nd line into the 2nd line socket it sits over the top of the other line.
How do I get L1+L2 to default to L1
Do you have a second phone? Be sure that phone is not defaulting to line 1. With 2 lines and 2 phones, each phone defaults to one of the lines.
Unplug the phones. Plug in the phone you want to default to line 1 using the L1+L2 jack. Now plug in the second phone.
Posted on Sep 06, 2008
Check TEL line
Is that what appears on the screen?
If so it means that it's not seeing the phone line.
1. Plug in a basic phone to make sure the line really is working.
2. Check the phone cord is connected to the correct socket (probably marked line)
3. If still no line change the cord and make sure that it suits the pin-out of your country. Most of the world uses pins 3 and 4 but the UK uses 2 and 5 on it's wacky BT flat plug. Israel uses this BT plug but uses pins 3 and 4 !!
Oct 27, 2013 | Uniden Cordless Phone
Connect Phone and I/F module , "incoming call" displayed couldn't hang up.
try recycing the power on that...hook up the two modules with power off, then turn power on..it is possible that connecting them while on, would glitch the system
Oct 22, 2008 | Polycom SoundStation2 Audio Conference
I can not access my main line
If a system defaults programming it assigns only lines 1 and 2 to each set.
You either had this issue or somebody removed line 3.
Call a tech in to program.
Aug 01, 2012 | NorStar Meridian M7310 Phone
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
Printer kicks me off internet
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
When i try to graph it says error and wont let me graph
Reset calculator to defaults
[2nd][MEM][7][2][2] Defaults set.
[Y=] on line Y1= enter your function then press [GRAPH]
You can draw several graphs on the same screen.
If nothing shows (except the axes) use [ZOOM] to Zoom in or zoom out or use [WINDOW] to change the values of Xmin, Xmax, Ymin, Ymax.
Hope it helps.
Hope it helps
Sep 09, 2009 | Texas Instruments TI-83 Plus Calculator
I have an MLS-12D phone that needs odd programming - picking up the handset to call out should default to our main line (Line 1) (right now it defaults to a different line ? Line 2). Also, it should NOT be...
Well, there is a lot of things to do.
First, here is how to do Auto Line Select.
Is it only 1 phone that should be making outgoing calls? Or is it not place any outgoing calls ONLY on line 3?
Jul 30, 2009 | AT&T Lucent MLS-12D Phone
RE: NEC DTP-2DT 2 Line Digital Phone HandSet
i believe the nec dtp-2dt maybe a phone system phone for offices. you didn't mention if it's for home or office use.a phone system phone will not work in a regular phone jack. it needs to go thru a phone system. also if you buy any 2 line phones, you need 2 lines for both lines to work. you can also have a 2 line phone with only 1 line and order a 2nd line if needed
hope this helps
wg
Jan 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
LINE 1
You can try the following:
Restoring the Defaults
This feature allows you to reset all the menu settings to the original default settings.
1. Press the MENU button.
2. Use the REVIEW  or to scroll to RESTORE SET.
3. Press SELECT.
4. Use the REVIEW  or to scroll to YES.
5. Press SELECT to save. To start over, press EXIT to return to the RESTORE SET menu.
If this does not help, and the cord is good (use another phone to test), then the phone is bad.
Hope this helps.
Jan 09, 2008 | RCA 25202RE3 Corded Phone
RCA 25205RE1 Phone Logo
473 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
