Question about Motorola Mobility HS820 Consumer Headset
HS820 won't activate 'voice dial' on Blackberry Pearl
Per instructions, a single short press on the MFB should signal the BB Pearl to respond with voice dial instructions. It doesn't -- instead, it does a redial of last number. This is supposed to occur with a LONG press, not a SHORT press.
I have two HS820's, both do the same thing. However, both work correctly (i.e. short press = voice, long press = redial) with my Motorola Razor.
Also, I have an older Logitech BT headset that DOES correctly work with the Pearl to initiate voice dialing.
Any thoughts?
  • Kangaroo1261 Aug 26, 2008
    all my hs820 will do is redial no voice dial. Im using a samsung and tried it also on katana phone and same thing
Did you find a resolution.  This is the same problem I am having with the Curve.
Posted on Aug 07, 2008
I want to get bsnl gprs in my bb pearl 8100 mobile What is the message i should must be phonemake<space>modelno.... so it is blacberrypearl 8100 or blackberry 8100 or...
It is pearl 8100.They need the phone model and not the company.By the way BIS only works for blackberry and not bsnl activate the Blackberry Plans just call 1505 or 1800 180 1505 from BSNL
Mar 23, 2011 | RIM BlackBerry Pearl 8100
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
I have a BB Pearl 8130 from Telus that I need to unlock (no sim)
Go to , and follow instructions there, then you will your unlock code with instructions to enter it .
Mar 01, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
Im unable to use internet on my blackberry 8100 with airtel connection
Check whether you are getting EDGE/GPRS in upper case.Have you activated BB services,if you have already activated BB services there may be a network issue also and check whether there is a check mark in blackberry internet services(Menu-Options-Security Options-Firewall-BlackBerry Internet Service)if there is a check mark on it remove it.If you are using BIS check the default browser is Internet Explorer of if you are a BES user default browser is Blackberry Browser.Menu-Options-Advanced Options-Browser-Press menu-change Options-select the browser according to the service.
Jul 14, 2009 | RIM BlackBerry Pearl 8100
Manual options of blackberry mobile 8800 gprs for vodafone
BB services are only available and activated on Postpaid not with prepaid.....and there can be no settings configured for gprs without any BB services activated
Jul 01, 2009 | RIM BlackBerry Pearl Smartphone
RIM Blackberry Pearl Can't hear incoming/outgoing calls
After receiving a message with sound, push the button on the side that activates voice dialing. It sometimes takes activating it twice, but it will turn the sound back on.
Mar 05, 2009 | RIM BlackBerry Pearl 8100
BB Pearl 8100 - can't hear incoming calls
Probably need a new ear piece speaker they are 26.95 at celldr
Feb 21, 2008 | RIM BlackBerry Pearl 8100
Paring Motorola HS820 with Pearl Blackberry
Conidering it's an HS820, and I have the HT820, I'm going to assume the passwords are the same: 0000.
Jul 14, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
85 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
