Question about Nokia 6310i
Nokia 6310i facia replacment
Can remove 4 screws but still held in place at top of phone, how do i remove?
At the top of the phone their is anouther screw it is located top left near aerial, release this and you will be able to seperate phone fascia
Posted on Jun 18, 2008
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
Tip
Samsung SGH-X150 disassembly, take apart.
How to take apart Samsung SGH-X150 Black Cell phone:
Time Required: 10 to 15 minutes.
Tools needed: Precision tools, Small philips screwdriver, Case opening tool or a plastic stick, or your fingernails.
Difficulty: Easy
Step 1. Remove the back cover, battery and sim card.
Step 2. Are you replacing the screen? Or are you looking into the keys or the mainboard?
If you wish to get to the display Go to step 3.
If you wish to get to the keys and the mainboard Go to step 4.
Getting to the display.
Step 3.
To replace the display, unscrew two Philips screws from the bottom of the display, they are under two soft tabs that you have to remove from on top of them.
Step 3.1. Use your fingernails or case opening tool to open the display cover.
Begin from the back and work towards the top, open the back and the sides, do not force open the front its held in place from there and you need to pull the plastic cover off looking at the picture below to the left
Step 3.2. After the cover is off, you get to the back of the display, on the top you have a few speakers etc.
Step 3.3. From the bottom release the connector by carefully pulling the board upwards.
Step 3.4. From the top, use a flat screwdriver to get the speakers out of their slots so the circuit board with the display comes off.
Step 3.5. The display is now free from the cover, you can remove it from the case.
Getting to the mainboard and keys.
Step 4. With the back cover, battery and sim card out. On the back of the phone, there 4 Philips screws. Marked with red dots.
Step 4.1. With the 4 small screws out, start using the case opener tool or your fingernails to release the plastic casing from the back of the phone. It is held in place similarly as the top of the phone in step 3. Begin from the sides and the bottom of the phone, the top is held in place and won't open until the sides and the bottom are lose, then you can disconnect the top part.
Step 4.2. As you release the back cover, on the side the up and down plastic key drops out remember to replace it properly when you assemble the phone.
Step 4.3. Disconnect the display cable, the mainboard is held in place by plastic clips on the top, carefully release the mainboard, you may break off a clip or two from the case, if that happens, no worries. The screws will still hold the casing together. the area is again marked in red.
By now you should have the phone completely disassembled / taken apart.
We are done.
Assemble in reverse order. Total 6 screws in this phone, 2 on display 4 on case. Held in place mostly by plastic clips.
Thank you for reading, I hope this has helped you.
-Ekse
on Mar 14, 2010 | Samsung SGH-X150 Cellular Phone
Need unlock code for Nokia 6310i. IMEI No: 351457208801776
For good place to get the unlock code for Nokia 6310i model, visit this site www.unlock-free.com/nokia-master/nokia-6310i.html, it provides step by step instructions and easy ways to unlock the phone lock network ..... while for the unlock code you have to give some information about the mobile site that is your IMEI number, network and country lock, then in a short period you can get the code ... ......... I
Sep 04, 2011 | Nokia Cell Phones
How do you remove the front facia door of a Teknik integral dishwasher
I have just replaced the facia on mine. It is a TKD795/4 so I would imagine yours would be very similar. Around the inside of the door are 10 starhead screws; 4 along the top and 3 down each side. On mine it is the 2 end screws along the top and the 2 middle screws down the sides that hold the facia on. It is best to remove one screw at a time to establish which ones hold the facia on and which hold the door together. The short screws hold the door together and should be replaced and left in place. It is the longer screws that hold the facia on; these only need to be undone enough to release the facia panel. Once you have undone the relevant screws, the facia will lift up enabling you to release the 2 clips at the bottom. Replacement is reverse of removal. Hope this helps.
Feb 26, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Nokia 6310i
You mean your phone have a weak signal? There are many factors affecting the signal of your phone. It might be the phone service provider whose encountering a technical difficult on there system, there is something blocking your phone to receive strong signal like the trees,large building or maybe you are in a remote area where signal are difficult to reach.
But if you mean your phone is completely cannot receive any signal then it must be its hardware antenna inside that needs to be check or replace. You need some tools to do the repair like a soldering gun,screw driver and tester to do the diagnostics. If your unsure on how to do this then you need to visit Nokia Care Center about this.
Good Luck!
Don't forget to rate! Thanks..
Mar 30, 2010 | Nokia 6310i
6310i is turning off and turning on continue
it ight have virus ,reinstall the phone software from nokia care or anywhere else
Aug 06, 2009 | Nokia 6310i
Hi does anyone have any step by step instrcutions on how to replace the whole facia for the Nokia N95 8gb?
1. Slide the phone upwards and remove the two screws.
2. Slide the phone the other way and remove the other two screws.
3. Using a plastic pryer, remove the front cover.
4. Lift off the ribbon cable off the lcd screen carefully and remove it from its holding (keep it in a safe place for installing it later on)
5. Using the plastic pryer, lift off the back cover off the phone.
6. Unscrew the 4 metal screws to take off the top part where the power button is and the bottom part where the battery/usb part is.
7. Install the housing and put everything back in order.
Cheers.
Apr 14, 2009 | Nokia Consumer Headset
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
How do I get the back cover off the 6310i so that I can take my sim card out ?
Just remove the battery by presing the button near the top at the back and slide the battery downwards. You can now access the SIM card.
Mar 03, 2009 | Nokia 6310i
Nokia 6310i Logo
106 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
