Assuming your old hard drive is functional, you can buy a drive enclosure that will allow you to connect your old hard drive to another computer with a USB cable. The 2 most common hard drive interfaces are IDE and SATA. The enclosure has to match the type of drive you have. I recently bought a SATA enclosure on eBay for less than $!5.
Kindly let me know the beep code sequence (the alarm) which you are getting. Just switch on the computer and carefully listen the alarm one long continuous beep or short beep or one long followed by one short. This information is necessary for providing you the solution. Online chat would have been more helpful to restore your pc.
Ok one long beep followed by one short beep symbolises two problems. Don't bother about your HDD thats just fine. Don't try to repair or format your hdd. Simply open the cpu take out the RAM if you have two RAMs inside then take both of them out clean them and put only one inside and try to switch on your pc. In case you have only one RAM then just take it out clean it and change the slot. If after doing this also you get the same beep code error then change the monitor and boot your pc.
atleast let me know did that fixed ur pc or not.
One Long Beep followed by a short beep.
