Question about Microsoft Windows Vista Ultimate Edition
Windows Vista Programmes
I have the windows vista on my laptop,I can not save something that I type on my usb and use the works desktop to print it, the work computer is using windows xp,the usb just won't open at the works pc,I also need to set up a email address for me on the mail account that is on my laptop.
  • 60 Answers
Your queries are not linked.
Please specify if they are
1) You can not save something that I type on my usb and use the works desktop to print it,
2) the work computer is using windows xp,the usb just won't open at the works pc
3) I also need to set up a email address for me on the mail account that is on my laptop.
1) Check if the USB drive is locked or write preotected (there should be a up-down button in the back of the USB. unlock and save.
2) If you have connected the work PC and Laptop, to get access in USB in work, you need to allow access to the other machine.
Select the drive, right click,properties,share and aloow access to the Laptop.
3) Not clear about the query. if you are looking to configure outlook,
http://www.webdevelopersnotes.com/tips/internet/configure_gmail_in_outlook_express.php3
Posted on May 26, 2008
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
On previoius Dell products ALT-PRNT SCREEN used to capture the active window this does not seem to be an option on the E4310. How do I capture an active window?
Check if you have to press the fn (function) key on your laptop before pressing Print Screen, you can tell if they are both the same blue color.
When you press ALT+Print Screen, you only capture the active window, when you click print screen you capture the entire screen. Then you will have to press CTRL+V on your keyboard to paste into paint. If you have windows Vista, you can capture screen shots much more easily using the Snipping Tool included with Vista.
Here's a How to guide to refresh: (Ref: http://graphicssoft.about.com/cs/general/ht/winscreenshot.htm )
  1. Press the Print Screen key on your keyboard. It may be labeled [PrtScn].
  2. Open an image editing program, such as Microsoft Paint.
  3. Go to the Edit menu and choose Paste.
  4. If prompted to enlarge the image, choose Yes.
  5. Optional: Use your image editor's crop tool to crop out unnecessary portions of the screen shot.
  6. Go to the File Menu and choose Save As.
  7. Navigate to the folder where you want to save the image.
  8. Type a file name for the image.
  9. Select a file type.
  10. Click the Save button.
Tips:
  1. Hold the Alt key down while pressing Print Screen to capture only the active window.
  2. Generally the GIF format works best when saving screen shots of application windows. The JPEG format usually makes screen shots (especially those with text) blurry, blotchy and discolored.
  3. See related resources below for more screen shot tips and listings of screen capture software that offers many more options for capturing screens and portions of screens on Windows and Macintosh computers.
  4. The Windows "clipboard" is a term used to describe the temporary storage space in memory where an item is placed when you copy or cut. When you paste, the item is transferred to the program you're working in. If you copy something else, the old item is replaced with the new. You can't manipulate the clipboard directly; it's only used for copy and paste operations.
Good Luck
Jun 06, 2011 | Dell Latitude E4310 Laptop Computer (Intel...
I saved and edited my videos in windows movie maker at my vista, and the project was save as .MSWMM and from my vista I saved it in usb to transfer the file in windows xp, but unfortunately windows xp did...
Ok try formatting the usb drive under XP, put a small file on it, say a pic or something, then take it to win 7 & see if win 7 is OK with it, if OK, well then copy files and take back to XP.. ya should be able to "see" ya files now.
Jan 27, 2010 | HP Pavilion a1610n PC Desktop
My windows 7 Pc cannot access my windows vista
you should check two things:
1- Check in your windows Vista if the file and print sharing is enable in the "network and sharing center"
2- Try disabling your firewall in your windows Vista to troubleshoot. If your firewall is blocking the connection you might have tp add a rule to allow access from your windows 7 to your windows vista
Nov 30, 2009 | 2wire (1000-000057-000) Modem
A vista OS is failing to detect lexmark 8300 via USB port When i plug a flash or another usb device on the same port it plays i tried to reinstall the drivers but they cant work. what could be the problem...
ok.....
  • click the start button.
  • type "services.msc" in the run bar.
  • Allow it through UAC.
  • now search for an entry called "print spooler
  • double click it
  • in the startup type type select "automatic".
  • restart system
  • this should fix ur problem.
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
Want to save the photos in memory to the flash drive.
vista is really bad with a lot of programmes a lot of programmes dont work even if you have the drivers and there is nothing you can do i would go back to windows xp
Dec 15, 2008 | DXG Technology DXG-305V Digital Camera
Nero 8.0 and vista
Reinstall the nero 8 and restart the system. If problem persists then it is better to change the OS to windows XP SP2.
Oct 28, 2008 | Microsoft Windows Vista Ultimate Edition
Trasfering emails and contacts from Windows Mail to Outlook Express
Hello
you can do it in many ways but I think this is the simplest.
copy addressbook
1. go to file>export>windows contacts
2. and save it to same backup folder on your desktop
copy msg
1. create a folder on your vista desktop(backupmail)
2. start vista mail
3. drag your messages that you want to the XP computer to the desktop backup mail folder you most drag emails you cannot drag and drop folders.
4. when you are done move the folder on a USB stick or something and move it to your desktop on your xp computer.
copy addressbook
1. go to file>export>windows contacts choose CSV
copy your mail account.
1. go to tools>accounts>export
2. save the file in you backup folder on your desktop
then copy the backup folder on your desktop to a usb stick or something to transfer it to your xp computer
your xp computer.
import msg
1. paste the backup folder to your desktop
2. open outlook express and drag and drop the msg from the backup folder on your desktop
import contacts
1. click file import "other addressbook" and choose "text file" navigate to the desktop backup folder and you should find a file to import click OK.
import account settings
1.go to options> accounts
2. then mail tab and click import button
3. navigate to the backup folder on your desktop and choose the iaf file to import
then you are done
good luck hope I helped, get back to me if you need more help.
Sep 18, 2008 | Microsoft Windows Vista Ultimate Edition
Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
Jul 03, 2007 | Sony CLIE PEG-T615C Handheld
Microsoft Windows Vista Ultimate Edition Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
