Question about Nintendo Wii Console
Wii USB 2.0 4 ports hub stopped working
We have a Wii and the USB 2.0 4 ports adapter stopped working. Waht do I have to do to get another one?
  • Anonymous Jun 30, 2008
    mine worked for the first day only...can i just get a USb hub from say ,,WalMart and use that instead???
  • bruno123456 May 11, 2010
    You mean the two at the back?
All you have to do is take out the USB ports and replace it with a new one just make sure the wires are connected to its right spot and also you can get great deals on eBay for some
Posted on Jul 16, 2012
    Problem Solver:
  • 14 Answers
In that case, have a look at the wii manual and at the last page, there will be a number. Ring it and ask if they could replace you USB ports. You may lose everything on your wii. You'll just have to ask. You could also check support.nintendo.com.
Posted on May 22, 2008
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
Dec 22, 2012 | Targus 4-port USB Hub Group International...
My computer is not detecting topway joystick
In order for a computer to detect a Nintendo Wii-based controller - you need to have a USB hub - that supports these controllers.
MayFlash Dual Port Classic Controller Pro Nunchuk USB Adapter PC for Wii...
Aug 30, 2012 | Topway Electrical Appliance Nintendo Wii...
OnBoard USB Ports Not Working and No PS/2 Ports!
When you boot the machine does it tell you what key to hit to get into the BIOS or System Setup? If so, press it. Maybe you need to try another keyboard if it won't allow you to press a key to get into the Bios or System Setup.
Apr 21, 2012 | Dell XPS 400 PC Desktop
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Apr 03, 2011 | Nintendo Wii Console
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Having problems with Nintendo Wii Beatles game. It allows for only one device (guitar, microphone, drums etc.) to be conntected. When the guitar is plugged in it does not recognize the mic and when the...
I dealt with Beatles Rockband Wii on 2 systems with 2 different configurations.
  1. Wireless Drum kit configuration. The Drum USB Transmitter has 2 additional USB ports, that allow Guitar/mic to be connected, plus there is the remaining USB port on the Wii
  2. Wired Drum kit comes with a 4 port USB hub, connect the hub to the Wii, and connect all instruments to the USB hub.
The Wii will only allow 4 controllers connected at once. So if you have multiple Wii Motes, then you may have to disconnect all but the one used for the Mic player (Press 1 on the Wii mote to unsync or remove the batteries)
Jan 02, 2010 | Video Game Consoles & Games
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Sep 14, 2009 | QPS (QU2RCT7) 7-Port USB Hub
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Nintendo Wii Console Logo
411 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
