Lg flatron 1710m monitor on switch doesnt come back out properly, monitor comes on and loses picture after 3 seconds, but power light remains on
  • ahmeds02ster Aug 27, 2008
    hi
    i have lg flatron 1710m monitor ,
    no backlight not on
    but power ok and sound ok and all replase the capastor but fault still.
    so pls help me what i am do.
    not one time backlight on.
    this my email.
    ahmeds02ster@gmail.com
    thanks
  • 56 Answers
Probably most likely a backlight problem.
Posted on May 22, 2008
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
Feb 10, 2011 | LG Flatron L1718S LCD Monitor
LG monitor not working.
More likely to have failed capacitors in the power supply section, that will be the first place to check. Please see the pictures here so you know what to look for inside, post back what you find so we can guide you further and it will help other people also.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Notes: I will assume you have already try it on another PC and it still does not work.
Apr 06, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
When i turn on my flatron 22 inch monitor the blue power button comes on for a second then goes out,it will not stay on.
HI,
your monitor is not working properly, bcoz monitor data cable no connected properly into the System or any internal problem in your monitor.
Thanks
Aug 15, 2009 | LG 22" FLATRON LCD Monitor
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
LG Flatron monitor remains in Power Saving Mode
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Nov 21, 2007 | Computers & Internet
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
