DENON DCD-825 CD PLAYER stopped playing
It started play certain CD's now and again.
Recently it stop playing completely.
Is it worth repairing and what do you think the issues are?
Mine did the same and I cleaned the laser lens and it cured it
Posted on Sep 08, 2008
  • 2 more comments
  • KEV P Jan 28, 2012
    that's the normal cure : so long as the lens is clean : and not cracked.... chipped, it should work very well : I just recleaned mine : cotton bud : or cotton bud and isopropyl alcohol seems to do the trick !
  • Vincent Nov 22, 2012
    Have a look here :
    Does the tray open ? If not, above link might help. else check tray switch inside and motor driver transistors (5 pairs of 2 on PCB close to front panel)
  • 4,234 Answers
Worse case scenerio is that the optics need to be replaced. These units use Sony optics i believe. The cost for optics can be anywhere from $15-$40. If the player has been good, I'd invest up to $75 to repair it. I think it is worth it.
Posted on May 22, 2008
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Faulty Denon CD player
The sled motor sounds like it's malfunctioning and not stopping winding at the beginning or end of the disc. There should be a detector switch to stop this. Might just need a good clean.
Nov 13, 2007 | Denon CDR-M30 CD Recorder
337 people viewed this question
