HP PHOTOSMART 2610 CANNOT INSTALL A REPLACEMENT COLOR INK CARTRIDGE CARTRIDGE IS A HP PRODUCE
  • Anonymous May 28, 2008
    My ink had ran out on my printer, so i had to get some replacement inks ie (Hp Original Black 339, 338 and Hp Colour 343, 344). My printer was working fine before i had to change my cartridges, but now it keeps saying ink cartridge not intended for this printer all i have done is put the new ones in same brand same hp number. Has anyone got a soultion for this ?.
    Many Thanks
    Kered
  • mest450 Mar 15, 2009
    Had to Uninstall the printer because it wasnt working, and now it won't install anymore. It gets stuck on the "detecting device" part of the installation"
    Hope someone yet help.
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Posted on Apr 07, 2008
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
  • 7 Answers
SOURCE: Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
Posted on May 27, 2009
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
http://www.youtube.com/watch?v=RTFOBtdthAc
Good luck
www.inkjet411.com
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 all-in-one printer. I've replaced my color and black carts. with refilled ones. My color ink drained all over the bottom of the inside of the printer. I am no longer going to be...
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Sep 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
My HP Photosmart 2610 won't recognise compatible cartridges, help
You can try buffing the contacts gently but this happens quite often with generic cartriges sometimes they just don't work. Contact the vendor and explain the issue, I reckon you'll find that they're fairly used to this problem and will request a return for a refund.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Some printing shows pink, I believe it is the blue - how do I check my ink levles in the Photosmart 2610 printer
your color ink cartridge is empty
check here hoe to refill it
http://www.youtube.com/watch?v=Ybj4awp_1ic
Apr 26, 2010 | HP Photosmart 2610 All-In-One InkJet...
My printer all in one hp photosmart 2610 is
Hai
I request you to check the ink cartridges as the paper is blank it could be due to empty ink cartridges or dried ink cartridges. Here is the weblink to replace ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&cc=us&lc=en&dlc=en&product=422000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257066&cc=us&lc=en&dlc=en&product=422000
Jan 04, 2010 | HP PSC 2355 All-In-One InkJet Printer
Howdo i refill my ink cartridges
Here are two links with refill instructions.
www.refillinstructions.com/HP/H22.htm
for the black cartridge, and
www.refillinstructions.com/HP/H23.htm
for the color one.
Hope that helps!
May 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
212 people viewed this question
k24674
jasbo
jasbo
