Question about Denon Audio Players & Recorders
DENON DCD-825 CD Player started to play certain CD's no and again. However on play it shows it's on track 01 but fails to play at all. Is it worth mending?
    President:
  • 2,712 Answers
Try using a lens cleaner and see if that helps. You can purchase one from any electronics store.
You can also try a hard reset: Unplu the device from the power socket, wait about 10 minutes and plug it back in.
If neither of the two suggestions work, you'll probably have to get your piece serviced.
Hope that helps! Should you have any further questions, please post them here.
If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
Thank you for using Fixya!
Cheers!
IrishDruid
Posted on May 22, 2008
  • Denon Master
  • 19,396 Answers
It is a dirty lens problem
  • 1 more comment
  • Ginko
    Ginko May 22, 2008
    If it happens always with same disk (or disks), then the disk is either dirty, scratched , or faulty.
    If
    disk is dirty (sometimes you cannot even see it but they are dirty),
    try cleaning the disk with cold water, and rinse well with a soft
    cloth, ensuring not to leave wet spots or cloth hairs.
    Done this try the disk again.
    If it is not the disk, then usually it is the lens. In this case you will have same problem with majority of your cds.
    To clean the lens start using a dvd cleaner and cleaning solution. This is a mild way to clean lens, often it is not enough.
    The complete lens-cleaning procedure involve opening the defvice, acessing the lens pickup, and manually
    cleaning the lens with cotton and isopropyl alcohol.
  • Ginko
    Ginko May 22, 2008
    As simple solution you can also try blowing some canned air on the lens. If this and the lens cleaning kit does not work, you should remove the cover, access the lens pickup, and perform a direct cleaning with isopropyl alcohol and soft cotton.
    If the lens is not dirty but scratched or opaque you may need to replace the lens pickup, in this case the job may not be worth.
    Here is how the inside looks like on a Denon similar model:
  • Ginko
    Ginko May 22, 2008
    You should have accepted best solution, the accept in bold from other expert was deliberately misleading. Next time you use Fixya accept solution only when you are sure it contributes in solving the problem. This will improve our rating system.
    Regards
I have a Denon DCD820 from the late 80's. This week I wanted to reuse it after remodeling my house and putting it aside for one year. When inserting a cd, sometimes it starts spinning and the shows the...
Couldn't find much for that specific Denon model but there is lots of info on basic CD player trobleshooting. If this video isn't helpful, do a youtube search or google "cd player troubleshoot"
Jan 08, 2015 | Denon Audio Players & Recorders
Where can i get a remote control that works with my denon dcd-f107 cd player
I show a GE universal remote as working with Denon equipment
Feb 23, 2013 | Audio Players & Recorders
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
DENON DCD-825 CD PLAYER stopped playing
Mine did the same and I cleaned the laser lens and it cured it
May 22, 2008 | Audio Players & Recorders
267 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
