Question about Sylvania 6419TC 19" TV
Your comment You responded to my problem by saying "Intermittent problems are the toughest to track down, but usually have one of two root causes. Cold solder joints are an intermittent contact between where a component (transistor, etc) is mounted to the circuit board and the electrical contacts of the board itself. The other cause is components which break down under heat. Either way, if your not much on troubleshooting, have a TV shop service it, it can be easily repaired." Is this expensive, should I just buy a new set?
  • 111 Answers
Hi, I posted back, maybe you didnt see... says...
Depends on what shop finds. Personally Id get $50 for fixing something like this, but not all shops are so honest, if you know what I mean. Some shops will give an estimate before actually making the repair.
Posted on May 23, 2008
Tip
Resolving intermittent Windows USB device issues
PROBLEM: USB Devices (Both internal and external) work intermittently.
DISCUSSION: Issue is caused by Windows power management disabling the USB Root Hub to save power (This option is on BY DEFAULT in all Windows installations)
RESOLUTION: Open Device Manager, scroll down to the USB Root Hubs Listings (There may be as few as two most I've seen is 7) Right click each hub, select Properties on the drop down menu, then click the POWER MANAGEMENT tab. There you will find a check box to allow windows to turn off this device to save power. Uncheck the box and close the window, repeat on remaining USB Root Hubs, then reboot.
This will resolve most intermittent USB device issues.
on Dec 03, 2009 | Computers & Internet
What would cause 99 Plymouth voyager to stall while driving and now won't restart but turns over.
Could be many many things. We need some more detail to assist.
Has this happened more than once?
Was the CE light on?
Electrical shorts/intermittent contacts are the toughest things to track down.
Which engine do you have?
Mar 14, 2015 | 1999 Plymouth Voyager
92 s10 blazer 4.3z intermittent start
Occasional problems are the toughest to solve. You have to narrow down the possible causes when the engine fails to start. You start at the coil and see if you have spark, then continue from there. The worst part is not knowing for sure if you have fixed it.
Could be the coil, ignition module, a relay, or a long list of things.
Jul 06, 2013 | Cars & Trucks
I have a 03 yz 250 How much PSI do I put in my tires for racing track
The factory recommends 15PSI. I usually run 12PSI.
Depends a lot on what tires you have and what kind of "track" you are riding. You typically want a firm tire (more pressure) for a soft surface and a softer tire (less pressure) for a hard track but there are always exceptions depending on the details of the track and what tire you have mounted up. If you are riding a track with a lot of hard braking bumps or firm ruts or even tree roots (if you ride trails) you should run more pressure - like maybe 13-15PSI. If you run less than about 10PSI you risk pinching the tube and getting the rim damaged from sand intrusion between the bead and the tire which can cause a lot of problems unless you change your tires frequently and run multiple bead locks. To run really low pressures usually means you don't have the best tire on your bike for the conditions in my opinion.
To simplify:
Soft track, hard tire - run 12-15PSI
Hard track, soft tire - run no less than 10PSI
Sep 28, 2011 | 2003 Yamaha YZ 250
I get intermittent ABS, traction control and power steering warnings simultaneously. After the ABS & traction indicators stay on typically until I restart the car . I checked in with on-star and they...
Usually when I see this the problem it's related to one of the wheel speed sensors not giving the correct signal to the ABS system. A missing or faulty sensor reading will cause the ABS and related systems to turn off which causes the warning lamps to come on. The reason it works again once you have shut off the car is that the system resets and works until it sees the problem again. I would have the service codes read with a scan tool. Once that is done the problem is usually fairly easy to track down.
Jun 29, 2010 | 2005 Pontiac Grand Prix
The passangers window is electric and it will roll down but not up
Hello... This problem is usually associated with a bad switch or a bad window motor. One way to tell which one is listen for the sound of the motor when trying to raise the window. If you hear the motor trying, it is not the problem. Then it could be something is stuck in the window track.
If more help is needed.. Respond to this forum and post a comment.
Good Luck... Mike
Jan 01, 2010 | 2001 Dodge Stratus
Cuts out while driving along . Not a lot to say, have changed the crank handle sensor.
There are many other causes to investigate. Intermittent shut down can be caused by a bad ignition switch or other intermittent bad connection in ignition system, fuel pump beginning to fail, coil beginning to fail or a bad relay. This is the kind of problem that shops hate because during testing, unless something has left a stored code, everything will test fine When the engine shuts down, you need to determine what's missing ...fuel or spark. Then you can begin to track down the problem. You will need a decent digital multi-meter and a manual such as chilton or haynes as a guide for those tests. No competent tech will replace parts by guessing...you should not either.
Oct 20, 2009 | 1996 Jeep Cherokee Sport
Gtalk not showing my current album status... :-(
gtalk is fully compatible with wmp 11.
if it stops showing the current track,
open wmp,
right click on the bottom pane,
goto tools-pluggins-options.
select background,
check gtalk.
that should solve ur prob.
Dec 17, 2008 | Google Talk
TV goes out
May 22, 2008 | Sylvania 6419TC 19" TV
Sylvania 6419TC 19" TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
