Question about Epson ACULASER CX11NF All-In-One Printer
Service reqd E511
Require
I was able to get hold of a schematic diagram to locate the part number for sensor :
part code 2090463 SENSOR TR-0
When I inspected the original part the pcb was cracked therefore the sensor was unable to dectect the 'mirror' which is a silver square located on belt on photo con unit.
If you require a copy of the schematic diagram (pdf) let me know an address to send it to.
Regards
Rob
Posted on May 23, 2008
Error: service reg E511 what does this mean?
Part of the photoconductor unit known as the transfer belt is not being detected when the E511 Service Requested error comes up. Epson in the UK has the troubleshooting outlined here:
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support;jsessionid=035E9EA2127A8A5A478481112D9F98B2.acc2?target=article&extn=.html&articleId=1319
Jun 19, 2010 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
Service Req E511
e511 is to do with the photoconductor unit which sits under the top lid
usually detector underneath the photoconductor dirty or the wide rubber belt then runs throuigh the photoconductor is sligthly off to one side
Feb 24, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
Maint REQD lighting in the dashboard
It means: (Maintenance Required) get your owner's manual and match ur milage to what your owner's manuel's service requirements recomend..
Dec 27, 2008 | 2006 Toyota Camry
Epson Aculaser C1100 Printer suddenly stopped printing
To my knowledge Error Code E511 refers to photoconductor and/or its associated components. It is possible that:
  • the photoconductor requires a bit of cleaning and to be reseated snugly;
  • the black rubber conveyor (transfer) belt inside the photoconductor moved away from its path;
  • the silver square reflector on the transfer belt needs cleaning;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Epson c1100
Probably need a new photoconductor - cheaper to buy a new printer....
Jun 23, 2008 | Epson Aculaser C1100 Printer
No functions are working, error code E511 shows in dialogue box
E511 is in regard to the photoconductor unit. There may be the need to clean the black belt from dust accumulation (other users have reported success by that) whilst I had success by cleaning the surface of the optical sensor on the left, accessible after lifting out the photoconductor. Keep the photoconductor shielded from light while you do this. It usually about stray toner accumulated on surfaces within the printer. Be careful how you remove "dust", a vacumn cleaner can catch fire because the dust is susceptible to electrostatic charge build up.
Hope this helps.
Jun 22, 2008 | Epson ACULASER CX11NF All-In-One Printer
Service reqd E511
E511 is a TR0 Sensor Fault. Can be caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Not really something easy to fix at home.
May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
225 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
