Question about Apple iPhone Smartphone
My i phone touch screen is not working
Hi,   My i phone touch screen is not working when I tap it. It seems like only the slide to unlock is currently working now. Please help.
THANK YOU.
  • Warlock153 May 23, 2008
    4gig iphone, UPPER part of the screen is dead and will not respond to touch. Everything in on phone still works fine
    Problem Solver:
  • 9 Answers
Have you dropped it alot?
I dont think this is a software problem, its definately hardware.
For your sake i hope im wrong, but if im right you'll need to change it out.
You can get replacement touchscreens on ebay and theyre pretty simple to change if your electrical minded. Hardest part is opening the iphone without damaging the back casing.
I opended mine and damaged it the first time. Needed to get a replacement on ebay, lol
Posted on May 28, 2008
Need help with unlocking phone ,keeps staying on one screen and keeps talking can"t operate phone
What kind of phone? If the battery can be removed try that. Is it new or was bought used? Almost sounds like a bad touch screen or corrupted operating system.
Jul 04, 2016 | Cell Phones
9 sciphone. the screen, has barely any function. the part where to slide to unlock, i can't get it to slide. somtime it will slide but then it won't unlock.
Hi, The touch pad on your screen is weak and does not function properly again, that is why you can unlock from the sceen. Needs to be replaced, it happens most times when a phone drop the flow or hits somewhere.
The only solution is to replace it with a new one.Thank you.
Take care.
May 20, 2010 | Dual Electronics CECT P168 Cellular Phone
Lower Half of my touchscreen on iphone does not work!
seems you have iphone 2g phone. your touch screen problem and needs to be replace.
Apr 28, 2010 | Cell Phones
Iphone 2g stuck at slide to unlock screen
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Jun 18, 2017 | BoxWave Corporation Apple iPhone 2G...
I just got a new i68 and it wont unlock.
try calibrating your touch screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 07, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
The silde to unlock will not unlock the i9 phone
Have you tried Calibrating your screen?
. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out.
Apr 30, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 Phone Unlock wont move
Try Calibrating the touch screen. Listed is the instructions how.
Apr 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Apple iphone touchpad not working
my iphone touch pad in not working..
Apr 25, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
79 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
