Powering down i have a micron millennia pc and when i select turn off from the start menu you can hear the hard drive click off but the screen still says windows is shutting down but the pc never totally goes off unless i hold down the power button. any suggestions would be greatly appreciated
  • Sunnyday1997 Feb 13, 2009
    I have the same with clean installed xubuntu. I think this is because it is an older type of power supply which not support power down mode.
  • 101 Answers
Hi your system is infected with a Worm which does not allow the comp to shutdown and power-off . An antivirus software could correct this or in my opinion cleaning the hard disk by formatting it and reinstalling the OS would be better option.
Posted on May 24, 2008
How do I reboot my Toshiba Satellite C55 without a
If your recovery partition has not been deleted you might be able to do it. See if you can access recovery mode
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
Oct 18, 2014 | Computers & Internet
I need an operating disk to boot up my micron pc millennia
Donwload a LiveCD or similar, like UBCD or Hiren's Boot and try them first.
Oct 06, 2014 | Computers & Internet
How do I reset the Compaq Presario 1200
Step 1:
which operating system ??
Back up to your external hard drive all of the items on the computer's hard drive that you would like to keep. The hard drive will be completely erased during the recovery process. Open the "Start" menu and then click "Shut Down" to turn off the computer. Allow the computer to completely shut down. Press the power button to turn on the computer and then press the "F11" button when "Press <F11> for recovery" is displayed on the bottom of the screen. Select "Recovery Manager" from the utility screen. Click "Advanced Options" and then select "System recovery." Click "Next" to proceed. Follow the on-screen instructions to complete the recovery process.
Feb 04, 2013 | Computers & Internet
Factory reset on presario cq58
Feb 02, 2013 | Computers & Internet
Factory rest on a presario cq58
Feb 02, 2013 | HP Compaq Presario V2000 Notebook
Hard disc is curropt and needs to be repaired but does not repair and will not allow navigation
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
have you tried options available in this menu?
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
I turn on the power, the power light comes on and the hard drive light for about 3 seconds than off...and i never get a screen. what could be the problem
Hello
First Remove all power (adapter power Cord and Battery (for laptops))
Hold down the ON button for 30secs (dispersing internal voltage)
Plug the power cord in only (ie leave battery out, for the moment)
Turn on
If it worked replace battery.
If it doesnt
Start your computer and press down on the "F8" key to get into the "Advanced Boot Options" menu.
Click the "Repair your computer" option on the menu and press the "Enter" key.
Select your keyboard layout from the choices given.
Click the "Next" button to enter the "System Recovery Options" menu.
Choose "Startup Repair" from the menu and press the "Enter" key to start the repair on your startup disk.
Dec 15, 2010 | Toshiba Satellite A135-S2386 Notebook
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
Is it possible to install Windows 2000 OS on a brand new hard drive in a Micron Millennia Computer that originally had Windows 98? Would there be anything on the motherboard that could prevent the...
Yes you would be able to install that OS on the system but the only thing you woudl have to look at is memory. professional version of 2000 requires 64MB of memory minimum and you need atleast a 10GB HDD. other than that, finding the dirvers may be a little hard these days and Windows 2000 is no longer supported by Microsoft so you will not get any updates for the OS post Nov 06
Feb 16, 2010 | Computers & Internet
Swapping hard drives won't boot windows
do 1 thing 1st you formet your hard drive if its done ite mean your hard drive ok and install it again . i mean OS. if not formet then submit your hard drive in service center or bye new 1. ple done if you r happy.
Jan 29, 2010 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
