Question about Brother SE-270D Computerized Sewing Machine
Threading the needle of the embroidery machine
I've just bough a second had Brother embroidery machine.
I am now having a problem threading the needle with the automatic needle threader. i follow the guidelines to thread the cotton but when the mechanism comes through to thread the cotton through the needle it doesn't go through the needle it is as if the mechanism just misses the cotton and doesn't thread it through the cotton..
Please help!!!!!
  • Anonymous Nov 14, 2008
    I don't understand how to use the electronic threader on my brother computerized sewing machine. It makes me really mad. Maybe I don't see what I'm supposed to hook the thread around, but it just slips off. When I push all the way down on the automatic threader lever.
  • Anonymous Mar 31, 2014
    when I attach the embroidery box and start to embroider the thread spews out of the top tension. the automatic threader wont thread and when sewing it pucker the material.
  • Brother Master
  • 1,388 Answers
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
Posted on May 23, 2008
Thread is not staying in the needle bar thread guide. It is slipping loose.
hi try to make sure the thread is in between the tension wheel as you thread and sometimes turning the spool over works hope this has been of some help
Dec 12, 2014 | Brother Se400 Computerized Embroidery &...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
Upper thread keeps breaking on my Brother HE-1 embroidery machine, tried adjusting the tension and nothing seems to work
could be a dull or bent needle. Could also be a burr on your hook. Try changing the needle first. If it's a burr on the hook or the needle plate, you have to take it to a tech for maintenance
Sewing Tech
Oct 25, 2013 | Brother HE-1 Embroidery Machine
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Dec 07, 2009 | Brother SE-270D Computerized Sewing...
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
260 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
