Tomtom ONE GPS Receiver Logo
Posted on May 22, 2008
TomTom One XL-S update has lock feature
How to unlock ?
The TomTom goes into a reduced menu (single page) and displays message it is in a locked mode.
How to unlock ? Can't find anything about this "feature" which seem to have appeared after a recent auto update (a few weeks back).
Thanks
A
Anonymous
I want it in english.
2answers
How can I unlock osd on my TV viewsonic n2011
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds.
http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
How to unlock rp5020
Hi Louis
This is from page 5 of the manual:
Keys lock
This feature avoids accidental key activation during recording or
playback.
1. Press and hold MENU button for 3 seconds, LOCKED will be shown on display. (LOCK icon will lit) s
2. Press and hold MENU button for 3 seconds again to unlock keys.
You can a copy of the manual here: RCA RP5020 User Manual
Trust this helps
Alan
Cd Code need code for am fm / CD /cassett player purchased at junk yard out of a 2000 Suburban and putting it into my 2010 Chevy Colorado which has only basic am / fm radio? How do I get past "locked"...
That is a security "feature" on GM radios to deter theft. The following instructions has had sucess with other GM vehicles. If not, only a dealer has the equipment to get past lock screen.
This works on vettes with theftlock. Try it on the tahoe and let us know....
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can "unlock" your radio and then "re-lock" it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes
into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner's manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP
mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure: 01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don't take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You'll hear "Invalid Code, try again"
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now "un-locked" and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner's manual. Use the code from STEP 11 instead of your personal code. Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
http://chevroletforum.com/forum/tahoe-suburban-25/help-radio-locked-8220/
5helpful
I put a lock code now I forgot. It and cantget in my phone.
Messages & Display Issues: The display on my phone reads "Locked" or "Keyguard"
  • If you see the word "Keyguard" on the display of your Kyocera phone, you may have activated the keyguard feature. Press button below "Keyguard," then press 123 or the "OK" key to unlock the Keyguard feature. The phone will display "Keyguard Disabled."
  • Some Kyocera phones also have the phone lock feature available. If the phone lock was activated, the default lock code is 0-0-0-0 (4 zeros). When your handset is programmed with a mobile number by your Mobile Service Provider, the default lock code will change to the last 4-digits of your mobile number. To change your handset lock code, you must go to the Security menu, then select Menu > Settings > Security > Current 4-digit lock code.
  • 3helpful
    The safety lock is enabled and I am unable to turn this off. I am also unable to navigate to an address or favorites. It is also on the wrong time zone.
    The safety lock is active only while the device is moving. When you stop, you can access all buttons again. To switch off the feature,
    • Tap the map display to go to the device main menu
    • Tap "Change Preferences"
    • The TomTom XL device hides many menu options by default. If you can see an icon "Show ALL menu options", tap this one next. It should show as "Show fewer menu options" now.
    • Locate the icon "Safety Preferences" (a red heart on blue background) and tap it. This will allow you to deactivate the safety lock feature.
    • You may want to hide the lesser used menu options again.
    In order to set the time properly:
    • Tap the clock button to set the time and to change the way the time is displayed.
    • The easiest way to set the time is by tapping the Sync button. Your ONE XL will then take the time from the GPS information it receives.
    • After using Sync to set the time, you may have to adjust the hours depending on your time zone. Your ONE XL works out your time zone and always keeps the time correct using the GPS information.
    • You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
    When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
    I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
    I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
    Locking OSD settings
    When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
    Special messages display on the monitor screen for the following monitor conditions:
    • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
      • For the w1858 monitor: 1366 x 768 @ 60 Hz.
      • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
    • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
    • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
    • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
    • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
    • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
    5helpful
    2answers
    NEED UPDATES
    Yes, you can get SOME updates for free... indefinetely.
    You will need the latest version of TomTom Home software, available for free from www.tomtom.com.
    Install the software on your computer BEFORE connecting the TomTom GPC to the USB port of the computer.
    The free updates you can get are:
    1) "QuickFix" updates. This contains the global positions of GPS satellites, allowing the TomTom GPS to get a faster lock on the GPS satellites (the GPS will get a lock within 5-10 seconds of being turned on, instead of 2-5 minutes on some other GPS brands). It is suggested that you update the QuickFix at least once a week. If you don't do it often, the GPS will just take longer to find the GPS satellites, that's all.
    2) Minor updates to your map(s), but only the ones submitted by other TomTom users.
    3) Updates to POIs (Points of Interest), such as new stores, malls, gas stations, parking lots, etc.
    Whole-map updates ARE NOT FREE
    1helpful
    2answers
    How do i put a phone lock password on my samsung memoir
    The Security feature enables you to restrict the use of your phone by others and to restrict the types of calls.
    Various codes and passwords are used to protect the features of your phone.
    1. From Idle mode, touch Menu ➔ Settings ➔ Phone settings.
    2. Touch Security.
    Lock Phone
    When the Lock Phone feature is enabled, the phone is locked and you must enter the 4- to 8-digit phone password
    each time the phone is switched on.
    To change the phone password, refer to the next section.
    Once you enter the correct password, you can use the phone until you switch it off.
    1. Touch On or Off from the Lock phone field.
    Change Phone Password
    The Change password feature allows you to change your current phone password to a new one. You must enter the
    current password before you can specify a new one.
    Once you have entered a new password, you are asked to confirm it by entering it again.
    1. Touch the Change phone password field.
    2. Enter the current password and touch Confirm..
    3. Enter a new password in the New password field and touch Confirm..
    4. Enter the new password again and touch Confirm.
    The password changed confirmation displays.
    Note: If you change your password, be sure to write it down and keep it in a safe place. If you forget your password, your phone requires
    service to have it unlocked.
    Hi, just bought a one xl, have tried to set up my home address and I pressed a wrong button, Italy instead of u.k., got up 'change home location' on the screen and selected street and house number, tapped...
    age has nothing to do with new technology,
    if the language in One XL is Italian then use google translate
    TomTom One XL manual page 33
    Tap Change preferences in the Main Menu.
    (When you first start using your TomTom ONE XL, not all the buttons will be shown in the menu. Many buttons and some more advanced features are hidden because you will not need these features very often.To see all of the buttons and features, tap "Show ALL menu options" button in the Preference menu.)
    then
    TomTom One XL manual page 36
    Tap "Change language" button to change the language
    You can choose from a wide range of languages. When you change the language, you are also given the opportunity to change the voice.
    if your one is not One XL any TomTom manual can find here
    Hope this help
    20/Apr/09
    Top Tomtom GPS Experts
    k24674
    Mike Cairns
    Mike Cairns
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
