Question about IBM ThinkPad R51 Notebook
My IBM R51 2887 model LCD Screen Problem
Sir ,
I would be highly grateful to u, if u kindly help me solve my laptop's LCD screen problem.
Description: IBM Thinkpad R51 2887 .. Purchased Year: 2005
Two days back while i was working on my laptop suddenly a white patch appearted on the LCD screen.
The patch appeared vertically & is about 6 cms wide . I took it to the lenovo service station and i was told that the screen need to be replaced and since the laptop is out of warranty ; it should be purchased. And the cost is
Rs 16,800.00 /--
Learning about all this I am very much dismayed & don't know what to do.
I would like to know that, Is there any way by which some thing (other than replaceing the screen) can be done...
Sir PLEASE, PLEASE, PLEASE ,..............
HELP ME !!!!!!!!!!!!!!!!!!!!!!
GCP
  • 3 more comments
  • stalin1 Jun 21, 2008
    Sir, i have problems with my IBM Thinkpad r-51 model LCD. there is a big white patch in the middle of my lcd and from the biddle to the right end black screen disply. i can only see the left half of lcd. please assist me if anybody know.
    ....Stalin
  • malladi_appa Aug 07, 2008
    white patch came, and gradually changes to blue colour
  • malladi_appa Aug 10, 2008
    i was facing same problem
  • gauravjha83 Oct 06, 2008
    I have the exact same problem as described above. Same model, same year of purchase, same make. I checked the link that is given by the expert. The screen would cost me INR 13k. I might as well buy a new machine, instead of investing for this one. Can we get it repaired somehow. Any ideas?
  • PARDEEP Oct 26, 2012
    HELLO I HAVE A IBM R51 2005 LAPTOP' SCREEN 14'1 TO BUY, AND DDR1 1 GB RAM, IF ANY BODY WANTS TO BUY CAN CONTACT 9872319904
  • 100 Answers
My IBM Thinkpad screen has gone dark but I can still see a bit. Is there a key to brighten the screen?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Aug 29, 2010 | IBM ThinkPad T23 2647 Notebook
My IBM R52 laptop displays some vertical thin lines (red,green,blue,white,etc). I noticed this problem arises basically IBM R52 and R80 models. Some of my friends too are suffering from this problem and...
This sounds similar to a fault i had with an old dell laptop... very thin vertical lines running the length of the screen. Unfortunately it was an LCD problem, the screen was kaput replacing the screen solved the problem.
To test if it is an LCD fault, simply plug your laptop into an external monitor... if you get no lines on external monitor then its a faulty LCD screen.
Is that solution genuine enough for you?
Aug 27, 2010 | IBM ThinkPad R52 Notebook
I have a very old IBM thinkpad laptop and the srceen is very dull
go into your bios at start up press f2,del or f8 and you'll see some kind of brightness control pretty sure but their is several thinkpads
Mar 02, 2010 | IBM ThinkPad 600X Notebook
LCD Display problem
From your description it sound like you have a faulty video cable or the video connector on the motherboard is loose.
Reseat the connector and it may solve your problem.
Jul 13, 2009 | IBM Computers & Internet
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Hasee/Ibm Thinkpad R30 lcd screen
hello dear sir madam
how are you ...i wont to tell you that can you sell the laptop for me ...i am in nigeria and i wont laptop to use... so therefore if you like to sell you can mail me ...... this is my mail jamessmith0009@mail2world.com
Aug 07, 2008 | Compaq Evo N610C Notebook
IBM ThinkPad R51 Notebook Logo
1,170 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
