Question about Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop
The motherboard cannot detect the hard drive/ hard disk
Yesterday, i'd format the PC, it used the dell motherboard. i took or move out the hard drive from the place to the other PC that used the other motherboard from the diffrent supplier(not dell). i've install the Windows XP OS. when i move back or put back to the PC. the motherboard not detect the hard drive, is that the problem come from the motherboard?
    Sergeant:
    Champion:
  • 219 Answers
You may have a hardware issue or cheak the jumpers on the hard drive some computers use a slave drive and set the jumpers as such.Is not you will have to reinstall xp HOpe i helped:)And yes you can move a hard drive from 1 to another as long as it is the same op system.All that will happen is it will auto install all new hardware.
Posted on Jun 11, 2009
  • 56 Answers
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
Posted on May 22, 2008
I have a Dell Inspiron 1525 and when I turn it on it tells me NO BOOTABLE DEVICE DETECTED This happen one other time and I rebooted my computer and it came back on but it did not work this time what can I...
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key"
There may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the hard drive and also where it connects to the motherboard.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Sep 16, 2012 | Dell Inspiron 1525 Notebook
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
I recently replaced the motherboard, video card and hard drive in my dell d800. The hard drive is new, but when I try to boot-up the computer gives an error message that there is no hard drive detected....
If it says there is no hard drive detected, then the BIOS is looking for one.
When you place your system disk in the drive to load on a fresh system, if you are using Windows, it will automatically detect the pressence of a hard drive, initialize it and format it. If it doesn't, put the hard drive in a USB caddy and initialize it from another pc, then place it back in the notebook.
Hope that helps.
Nov 24, 2010 | Dell Latitude D800 Notebook
How do I replace the hard drive in my Dell
Did you format the drive before installing it on your laptop. Some laptop will not detect unformated hard disk. Try to format the hard disk somewhere else and check to see if the laptop detect it after.
Apr 11, 2010 | Dell Inspiron 2650 Notebook
I have recently attached a seagate hard disk with my pc already have a sata . the 2nd one is not detecting, help me
You have to initialize and format a drive before you can use it. A brand new unformatted OEM hard drive and installed it in my Windows Vista PC. The drive is connected to the motherboard via a SATA (serial ATA) cable, just like my original hard drive. This new drive was for data/backup. When I turned on the computer, the BIOS picked it right up. However, when I got into Vista, it did not detect any new hardware. I even went into the Control Panel and chose Add Hardware and let it scan for changes, but it didn’t find anything new. Windows Plug and Play If your drive isn't detected, there is no need to panic. Windows Vista is a little funny about this sort of thing, but it is quite easy to fix. The problem is that the drive is not initialized, so the standard plug-and-play procedure for adding a drive does not apply. First, you must initialize the drive, then it will allow you to format it. After the drive has been formatted, it will be ready to use.
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds. Your hard drive is now ready to be formatted. Formatting Your Drive Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Read more: http://www.brighthub.com/computing/hardware/articles/22069.aspx#ixzz0iPADjMwO
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Windows Installation on Dell GX150 PC it took more than 10 hrs.
by the sounds of it your processor which is the brain of your computers is damaged you can either replace the motherboard of purchase a new computer because 8hrs is a long time for a installation
Mar 13, 2009 | Dell OptiPlex GX150 SF PC Desktop
DELL D600- UNABLE TO DETECT HARD DISK TO BOOT SYSTEM
You might have to reformat the drive sounds like you got a virus in your boot sector on the hard drive.
I hope you backed up everything you needed. when ya get it running again get an external drive and make regular backups of your stuff.Where did it move the files to ? you should have a backup of your system on your harddrive that came with the machine when you bought it ,try to reformat with this sector of the hard drive its called d: backup
Dec 31, 2008 | Dell Latitude D600 Notebook
Hi there
Hello
that depends
is the old disk a IDE disk?
do the new computer have a IDE port on the motherboard?
if so you can put it in your new computer. but you cant move your OS and use the same disk. you can use is as storage.
I quess that your new computer has sata right? and I think its a bad idea to move your maxtor disk to the new computer because it can slow your PC down.
Good luck
Sep 02, 2008 | Maxtor Hard Drive
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop Logo
373 people viewed this question
Alun Cox
