Question about Neff U1661 Double circotherm super Electric Oven
TOC Hi I have just replaced my fan oven element but it wont work ( I have replaced it a couple of times with no problems) the element proveder says it is probably the thermal overload connector (TOC) and not the element. Where is the TOC, what does it look like, can it be reset and do I need to buy a new one? Hope you can help Cheers Tarzantony
  • 1 more comment
  • Tarzantony May 24, 2008
    Thanks for that. Here's the thing, the oven light and fan both work ok. By testing for continuity the power stops at a little cube shaped object with spade connections on either side, the thing is about 3/4 of an inch in size, is this the toc? There are letters on the object:
    Z/-2/43 followed by 10/250, where can In get a replacement?
    T
    On closer inspection the letters are: Z42/43.
    Cheers
    T
  • Tarzantony May 25, 2008
    Great! Many Thanks
    T
  • 75 Answers
Hi there if your toc is at fault you will have no oven function at all ie. fan, light, and timer display. i would first check your timer is not set to auto and is also got the time set, failing that your thermostat may be at fault.
Posted on May 24, 2008
Neff 1541 not heating with replacement element
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
Oct 03, 2017 | Neff Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
To blow the house trips it must be the element
Thermostats do not normally go short circuit.
The elements can be replaced quite easliy and cheaply
I would check that the fan is turning freely before you buy the element
Feb 24, 2010 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
Neff U1661 Double circotherm super Electric Oven Logo
525 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
