Question about Vacuums
Replacing vacuum belt
i have a hoover runabout ....the belt broke and i can't get the bottom off (other than break it off) to replace the belt...I took the brush off but the whole plastic bottom won't come off, there are no screws....this vacuum is at least 10 years old but i have never had a problem with it...i love it.....please help me fix this...........
  • buckshot12 Jan 26, 2009
    I have the same problem. Its a good vacuum that I hate to have to throw out.
  • lorareyes Jan 27, 2009
    Hoover Runabout unable to get bottom off to replace the belt!
thanks for your concern...........a friend of mine said you very carefully have to pry the top off and you can get to the belt.............it worked and i didn't break anything.........it now works fine............thank you again.
Posted on May 23, 2008
How to change belt on hoover runabout 44258-930?
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
How do you replace the belt on a hoover runabout sweeper.
This link will take you to a site with instructions and illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Mar 21, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
195 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
