Question about Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System
Guru my dvd player turns on then says protection and turns off
  • 8 more comments
  • bow2daking26 Jun 21, 2008
    i turn on the system and it says hello and then like 3 seconds later it says protection. i have disconnected it from the power but still nothing.
  • Anonymous Aug 26, 2008
    same
  • Anonymous Aug 31, 2008
    my peace of **** i have had for 2 days turns on and says protect and turns off.. what the **** is that
  • Anonymous Sep 30, 2008
    ahh i cant fix it.! ive been trying to. but everytime i turn it on it says protect and then it turns of right away?
  • Anonymous Nov 12, 2008
    a mi me pasa igual, y el caso esque es un regalo de empresa y no puedo cambiarlo, sabeis si lo puedo arreglar yo misma? el mio es un home cinema ht-x200.
    gracias
    it plays for 25 minutes then it says protection and then it turns off.if i unplugg it and put it back on it does the same thing.but it turns of 2 minutes after turning it back on
  • matt945 Dec 11, 2008
    System worked great for 4 yrs. Now I turn it on and it gives me "protect" message and turns off. I have checked all speaker wires, checked air flow around unit, etc. Any other ideas?
  • mlarias Dec 22, 2008
    I have the same problem. Had it for about 1 year, then it started doing this problem a week ago. I did smell an electrical burn one night, but could not figure out where it came from. I thought maybe it was the TV, because the smell was coming from that area. I'm thinking maybe something Zapped out in the audio system. It was after this burn smell that I noticed the problem with the theater system. Is this thing fixable or is it fried?
  • sabsfilho Dec 31, 2008
    When I switch on my Samsung HT-X40, it shows 'protection' in display and shut itself off after.
  • Anonymous Mar 03, 2009
I was moving around my large woofer speaker last night and then all of a sudden the unit went into protection mode. I tried all the various solutions posted on here and nothing worked. Then I went back to my speaker connections on the woofer and unplugged them and plugged them in again and it seems to be ok now. Very annoying problem. Can I suggest unplugging all the speaker cables and replugging them back in. Also another solution may have been holding down the power button when powering up the unit. Give all the above a try.
Posted on May 03, 2009
    Genius:
  • Samsung Master
  • 1,550 Answers
Your audio amplifier IC of your device arre damaged you gotta change it.
Posted on May 25, 2008
My dvd player turns on then says protection and turns off
Posted on Dec 20, 2010
RCA drc200n dvd player turns on & reads disc but
divx(R) protect video dvd model no.E370
Jun 09, 2013 | Televison & Video
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
My dvd player keeps displaying protected when i try and turn it on
there is a problem on the mainboard section of your player and the system halts on to prevent further damage..this requires a bench repair with a skilled technician.I would suggest to better bring it on the service center..
Jun 06, 2012 | Samsung Televison & Video
What's your problem?my toshiba dvd player has protection on and can't get it off
The protection circuit is sensing a load problem, a malfunctioning laser assembly or a failure in the audio/video processing circuitry, far cheaper to replace the DVD player.
Mar 10, 2012 | Toshiba Televison & Video
We have a 2 year old Polaroid TDX-03211C television. Teh DVD player does not work. I can hear the DVD spinning around, but the video player does not recognize that there is one in. Is there an easy fix? Is...
It could be as easy as cleaning the laser. If you are a smoker, chances are that the smoke got inside the unit and is causing an issue. Wont read disc. Need to take DVD player out of tv set and clean laser. If that doesn't do it, make sure u are playing the correct type of DVD'S. Some types wont play in tv, expecially if they were burned from a computer. Usually DVD-R'S play fine and DVD+R'S won't play on some dvd players. Give that a try and let me know how things turn out.. Sincerely HDTV GURU JAY.
Mar 25, 2011 | Televison & Video
I turned the DVD player off last night and this morning it will not turn on. Any thoughts, suggestions? I do have a DVD in the player that I need to get out somehow....
it is possible that the power supply unit in the DVD has failed. You will need to open and ccheck, the fuse might be open and if a new fuse blows out then the SMPS unit is faulty.
Possible that the Sm driver IC /driver has failed. Possible also for allied components to have failed.
Or else you can change with a new unit.
Helpful?
Aug 28, 2010 | Samsung DVD-V3500 DVD Player/VCR
PROTECT
http://www.usersmanualguide.com/
see if theres a manual here
May 04, 2009 | Sony DVP-NC600 Multi-disc DVD Player
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
Region free code for Samsung RTSHE10T
Multiregion sansumg
Turn on
Press the repeat button
  • for Region 1 use 2, 9, 3, 3 and 4
  • for Region 2 use 3, 8, 7, 6 and 7
  • for Region 3 use 5, 6, 7, 3 and 2
  • for Region 4 use 7, 6, 8, 8 and 4
  • for Region 5 use 5, 3, 8, 1 and 4
  • for Region 6 use 2, 4, 4, 6 and 2
Press 9
Press Repeat Button
Turn off and on again
Nov 14, 2008 | Samsung DVD-V4600 DVD Player/VCR
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System Logo
1,340 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
