Question about Samsung Digimax L730 Digital Camera
Samsung L730 stuck
The lens is stuck open and the screen won't turn on. The lights flash and there are noises, however. I've read to try tapping it. It doesn't work. Can we reset the camera somewhow?
  • 2 more comments
  • stacey18 May 27, 2008
    lens is stuck open. the power button has a blue light on around it but nothing is happening and the screen stays black
  • mightytwiggy Jun 02, 2008
    Lens is stuck open and the power button will not turn the camera on after being charged.
  • joseparkino Jun 09, 2008
    When I try to turn on the screen is blurred, the camera makes a loud beep then screen goes clank. Blue power light is still stuck on and lense stuck out, will not respond to any button.
  • Anonymous Jul 30, 2008
    My camera is doing the same thing!!! Help! how did you guys fix yours??
I tried turning it on, removing the battery, replacing the battery, and turning it on. This didn't work. When I repeated this but also removed the memory card, it did work.
Posted on Dec 21, 2008
  • 797 Answers
Many times this kind of problem is a result of more than just one thing. It could be caused by dirt or sand in the lens track.
It could be caused from lens parts being damaged from an impact. Look at my other posts on lenses and problems.
If there are noises from the lens, it is internally broken, more than likely the small gears are either broken or stripped.
Posted on Aug 01, 2008
I too was having problems as my camera switched on but had a blurry screen and would not focus.
I took out the battery while switched on and carefully cleaned the lens and magically when i placed the battery back and and switched it on ...IT WORKED!!!!
thanks for your advice.....was going to throw the camera away!!!!!!!
THANK YOU
Posted on Aug 05, 2008
Hi,i turned it on,then pulled the battery out(while still on)then turned back on and it came right...
Posted on Aug 04, 2008
When i turn on the camera, all i see is black. when i take a shot, black also.
Maybe the lens cover is not opened, check it out maybe it stuck. Have you tried to capture a picture in flash ON ?
Jan 16, 2011 | Samsung Digimax L730 Digital Camera
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Lens is out as though camera is on but screen wont come on
Try taking out the battery, give the connections a blow to free dust then try the on off switch.
Jan 13, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Nov 08, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730
This camera would have to be tested more, but it sounds like a ccd or sensor problem.
If this camera was made around the year 2000 or after a bit, then it could be a ccd problem common with many Sony made ccds in this period.
A loose connection internally could also cause similar problems.
Aug 01, 2008 | Samsung Digimax L730 Digital Camera
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
380 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
