Question about Radio Communications
Battery charging I noticed that when you put the walkie talkies on charge there is no indicator that advises you that it is being charged or even an indicator to show you the sataus of the battery- unless i am wrong please can you advise how to identify charging /and or staus indicator. as i have found the batteries to die out within .5hrs of use
  • 1 more comment
  • easycobra May 22, 2008
    help
  • easycobra May 23, 2008
    this is a very new unit 1 week old
  • Dean Pitts
    Dean Pitts May 11, 2010
    Depending on which radios you have, there are different indicators, even between different models from the same company. Please include the Make and Model of you radios so we can try to locate this information.
    Dean Pitts
    Rollin CBs
    Mt. Vernon, TX
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
First the lifespan of the battery is 300 times of charging,after 300 times it will eventually wornout,another tip is check also the battery terminal of your radio,sometimes corrosion can cause the bad contact,pls do check the terminal....
Posted on May 23, 2008
Charging/Charged Indicators
I don't know what model of radio, but here is what I would try: pull the batteries and charge them on the charger by themselves if your charger allows this. The lights, well, some manufacturers just miss the boat. Especially on low end or "beginner" radios. I have one brand I can insert with NO BATTERY and the light comes on. Talk about useless. Charge times vary by size of battery and charger output, minimum is 3 hours, 12 hours much more likely but I see a lot at 5-7 hours. Hope this helps, model and brand helps always.
Dec 12, 2015 | Walkie Talkies Radio Communications
When do I know the walkie talkies are done charging
Well, a wide open question like that is hard to answer since every manufacturer decides different ways to charge. Even by the same manufacturer. So, general question = a general answer. Overnight is typical. (8-12 hours). Some are quicker. As for when they are completed, low end radios (FRS, GMRS) typically have no indicators. It costs more to put indicators in and people buy these radios on price alone. The more you spend, the better the quality almost always.
Aug 01, 2015 | Walkie Talkies Radio Communications
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Charging Problem
You can ask the seller you bought the walkie talkie from.
Sorry, I don't speak English very well.
Dec 25, 2008 | Cobra Radio Communications
Radio Communications Logo
113 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
