Question about Canon FAX-JX200
TECHNICAL PROBLEM I tried to solve the problem whit my fax but it appairs continue AUTO PRINT OFF.How can I solve the problem
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Most often, Auto Print Off is activated by pressing the On/Off button, and documents are then stored in memory. Disable this function by pressing the On/Off button again.
The fax will also turn off Auto Print when the machine runs out of ink or paper, in which case, you should replace the ink cartridge or supply more paper. This situation usually results in display of the message Rec'd in Memory as well, and the unit will receive up to 30 transmissions or 60 pages maximum.
Posted on Jul 02, 2008
  • Cheryl Whalen Jul 02, 2008
    Sorry - I forgot to tell you:
    Please post back if you need further help, otherwise thank you for using and rating FixYa!
Code appaire COF 32
You need to have the drum and developer replaced along with the cleaning blade or if it was recently done it was incorrect was F8 RUN? Where counter cleared? if not that will cause this code and if a copy or print was run before F8 and counters where cleared then you need a new drum and developer
Jan 23, 2013 | Minolta Di3510 Fax
How can i generate a confirmation page from the HP CM3530fs
Information menu
Menu item: Fax Reports
Sub-menu item: Fax Call Report
Sub-menu item: When to Print Report Never auto print
Print after any fax job
Print after fax send jobs
If this answer solves your problem, please be sure to leave a positive feedback please
Feb 18, 2011 | Office Equipment & Supplies
I have a canon fax jx-300. How do remove auto
Hey!Simply press the on/off button once and it will go from auto print off to auto print on!Good Luck!
May 03, 2010 | Canon FAX-JX200
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
When trying to print the confirmation page - continually jamming - is there a place I could take the fax machine to close to Rivonia in Johannesburg SA?
Thank you for your email. we solved the problem by finding and removing a flower bud that fell into the area where the paper feeds through. The fax machine is working 100% now.
Kind regards
Diane Stevenson
Office Manager
Strats Inc
Rivonia
Nov 17, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or alcohol...you can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
Drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Screen display auto print off
Course:
[Manorhouse:
Try holding the button down just a moment as opposed to tapping. If it still doesn't work, please post a new issue, by selecting "Ask Me", and I will continue to help you through other troubleshooting steps. You need to make sure to check that all your other supplies are in place and OK! Thank you.]
Apr 22, 2008 | Canon FAX-JX200
Auto Print is set to OFF and I cant get it to turn to ON
If you press and hold the power on/off button the fax will switch between on and off.If you press the on/off button once for less than 2 seconds it switch between auto print on or off
Feb 26, 2008 | Canon FAX-JX200
Webcam
search for any cd cam driver imported from china.
put it in the computer, but don't run it.
- connect the cam.
- wait for the auto dedection.
- follow the setups.
- chose auto install.
- chose continue for the alert security message if he appair.
- at the end it's intalled.
- try to use it by msn.
Nov 02, 2007 | GE MiniCam Pro HO98656 Webcam
Canon FAX-JX200 Logo
95 people viewed this question
old marine
old marine
