Question about GE WBSE2090A Top Load Washer
GE-WBSE2090A2WW MY WASHER WILL ONLY GO TO SPIN CYCLE AND SPINS FOR EVER. WHEN YOU RESET AND PUT ON ANY CYCLE HALF THE LIGHTS BLINK AND THEN IT GOED TO SPIN AND STARTS SPINNING.
  • Anonymous Nov 11, 2008
    I have the exact same problem
    Sergeant:
    Champion:
  • 262 Answers
Your main control board is bad ( Electronic Timer) if you need one let me know I can sell you one at whole sale but i would need model number to get the right 1
Posted on Jan 08, 2009
My washer does not spin after the wash cycle . model ge gcwp1000ww
It sounds to me like the timer could be defective. Thanks
May 02, 2016 | GE Washing Machines
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
GE washer
SOUNDS LIKE A POWER ISSUE IF YOU HAVE A TEST METER OR BORROW ONE PUT INTO OUTLET AND SHOULD READ ABOUT 120 VOLTS THEN PUT THE WASHER ON SPIN AND SEE IF THE METER GOES DOWN AND HOW MUCH AND WHAT LEVEL IT STAYS AT WHILE THE WASHER IS SPINNING LET ME KNOW
Oct 27, 2008 | GE WDSR2080D Top Load Washer
Washer is leaking when draining...
Ok..so you checked al the hoses.. do you mean ALL the hoses inside the washer? or outside the washer.. chances are one of the hoses broke free durin the violent spin cycle of that over-sized rug.. and you haven't found it yet. If you have sufficient room to extend the washer out from the wall.. gain access to the inside of it from the back.. then check each and wvery hose connection/clamp to make sure they are secure.. also.. look at the pump assemby to make sure it isn't the source of the leak..then if nothing is obvious,, watch for leaks by using a flashlight and examining everything you can while it fills the tub.. Leaks are normally the easiest thiong to zero in on.. and ... try to have a few towels or wet/dry vac handy during all this.. Hope this helps...
Aug 30, 2008 | GE Washing Machines
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBSE2090A Top Load Washer Logo
325 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
