Question about Panasonic Workio DP-3530 Copier
Scanner software for scanner not working on one laptop. Was working before but now scan does not get received by laptop. No pop up. When you try to open document manager, sytem freezes. I have removed and re-installed twice. Appears firewall allowing panasonic as an exception. HELP!
  • 100 Answers
1. try to print a test page.
2. if test page ok, turn of all of your firewall application, then check if panasonic communication utility is running as seen
on task bar (blue colored icon near at the volume control)
3. if it is running, double click it (PCU). scanner configuration must appear
4. the scanner configuration details about how you receive the document (popup or etc), program to open (you may even use adobe pdf reader), and the display name of your computer that will be seen on scanner directory of the machine.
Posted on Aug 04, 2008
After the scan, the program cannot save the file.
Alright, Open the "paint " program from all program/accessories/paint".
click on the file and click on the option scanner and camera wizard after that you will get a option for "scan" please click on scan to make and change and once when scan get complete. click on file and click on the save as to save the document.
good luck.
Nov 13, 2009 | HP PSC 2355 All-In-One InkJet Printer
Dell 810 all in one printer/scanner not scanning
scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
Oct 26, 2009 | Dell 810 All-In-One InkJet Printer
Scanning Problems
If you can't run a scan when you manually press the scan button in your printer/scanner, try to OPEN the scanner's software in Start => Programs => then look for your scanner software associated with your printer. When the software is open, try to make a scan from there.
Regards!
Jul 11, 2009 | Dell 810 All-In-One InkJet Printer
Cannot scan from Lexmark printer onto laptop
As a work around try installing Windows fax and scan and using that program to scan your items - I have multiple printers and it works great for me
Aug 10, 2017 | Lexmark X3470 All-In-One InkJet Printer
Pops up lime wire, curser won't work, extremely slow
Try downloading Avast Free version. I have had great success removing things infected from LimeWire with this software. When you download and get it set up, it will ask if you want to set up a boot scan. Say yes. Let the system re-boot and run. if something pops up it will pop up a window with a siren on it. move everything to the chest. Do not delete anything as it may be a system file that you delete. Lime wire is a haven for viruses. I would suggest getting rid of it.
Dec 02, 2008 | Toshiba Satellite M35X-S349 Notebook
Scanner
Reinstall you software for the scanner .
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1849438&taskId=135&prodTypeId=15179&pro
Jul 23, 2008 | HP Scanjet G3010 Flatbed Scanner
Canoscan Lide 25
Mine just always says Cant Communitcate with scanner. i have tried 2 new usb cable and two different macs and pc it is a crap scanner i hate it with a passion
Jan 26, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
HP Photosmart 3210 All-In-One printer copier scanner
hi,
try this
> uplug the usb cable
> insert the cd which came along with the printer
> open the folder "util-->ccc" in the cd rom drive
> locate a file called "uninstall_l3"
> a black screen would be popped up. go on with the instructions.
this will uninstall all the hp softwares related to this printer from your computer even from the registry.
once that is done
> take out the cd and insert it once again
> click the install button on the screen which will pop up.
> when the software asks you to conect the printer, plug the usb cable back.
thats it.... try to make a scan. if it is still not working proceed to the following steps.
> unplug the power chord from the printer while it is turned on
> press and hold # and 3 button on the printer at the same time.
> while holding it, insert the power chord and wait for 5 seconds.
> release your hands
> when it is done, try to make a scan.
still not working????
you may have to service the unit.
thanks and regards
agnel
Jan 22, 2008 | HP Photosmart 3210 Printer
ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
Scanner won't scan
try connecting it to another computer. If it works, then it is a prblem with your computer, otherwise it is with your scanner hardware.
If you can open the scanner clean the circuit board with (Isopropyl alcohol) IPA solution. you can also try replacing the ribbon type cables connecting the print head.
If the problem arised due to dust accumulation, the above action should solve the problem.
Jan 14, 2007 | HP PSC 2355 All-In-One InkJet Printer
Panasonic Workio DP-3530 Copier Logo
144 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
