Question about Canon Computers & Internet
Canon IR2200 problem
Is there any particular reason why it would randomly turn itself off, despite being in the middle of a print job? Ours does this fairly regularly and I was wondering if there was anything that could be done to stop this happening. It's services regularly and is in good condition but there is seemingly no explanation for this behaviour!
Thanks
  • 38 Answers
There are a couple of things that can be checked for this. Some by yourself and some by a technician
  1. check that the power cable isn't faulty. There could be a break in one of the wire inside the cable or there could be a loose wire inside the plug. The machine uses a standard kettle cord, which you should have plenty of in the office. Try using a different power cable. Also mke sure that the power cable is connected firmly to the copier.
  2. maybe there is a problem with the power outlet to which you have the machine connected. try plugging the machine's power cord into a different outlet socket.
  3. maybe there is a problem with the machine's power supply. Have a technician have a look at this if numbers 1 and 2 above don't solve your problem. the same can be said for the mainboard of the machine.
  4. I've had one instance where the machine's software was corrupted and resulted in the same problem, but this was also accompanied by slow response times from the machine.You didn't mention that symptom but its still worth it to have a technician either format the hard drive and re-install the software, or even better to replace the hard drive and re-install the software.
Posted on Jun 08, 2008
I am attempting to set-up my printer threw a netgear wired router and can't get it to connect for some reason (using manufactures software even). My printer is a: Canon imageRuner 3300. I have attempted...
Often two firewalls on the same LAN conflict. Both are trying to do the same job; the conflict may cause an otherwise good Internet connection to drop. If this happens, use the NETGEAR firewall, and disable the other. Two situations are described here, but the general approach applies to any firewall active on a NETGEAR LAN.
The Windows firewall may be turned on without you knowing, for example, if the XP Network Setup Wizard was used.
To Disable Windows' Firewall
See Microsoft knowledgebase article: How to: Enable or Disable Internet Connection Firewall In Windows XP. (Note that you must be logged on as administrator, if you are not, no "Advanced" tab will appear as described.) For hints about using these Windows features, search firewall in Windows help, and select the article Enable or Disable Internet Connection Firewalls.
To Enable the NETGEAR Firewall
Consult your router's User Guide or Reference Manual. Look for sections such as "Using Basic Firewall Services" or "Allowing and blocking keywords, sites, services". Manuals are available for downloading on this site.
To Disable the Norton Firewall
  1. Right-click the Norton Internet Security icon on the system tray and select Disable.
To Disable the McAfee Firewall
  1. Uninstall McAfee
  2. Reinstall McAfee, selecting Custom Installation.
  3. Unselect McAfee Firewall.
  4. Finish the rest of the McAfee installation as you did before.
To Disable Zone Alarm
  1. Right-click the Zone Alarm icon in the System Tray, and select Shutdown Zone Alarm.
Also search the Zone Alarm forum for such issues as this product continually logging people off AOL, or Windows XP wrongly reporting that Zone Alarm has been turned off.
Nov 10, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I have bought a second hand canon ir2200 but it still needs codes from last owner to work which i don't have. Can i reset it myself? Thanks
HI,
here is the procedure:
enter service mode * 28 *
Under copier, FUNCTIONS, CLEAR, find PWD_CLR and then OK.
Turn off and on
Problem solved
Mar 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Bad copies on our Canon ir2200
Most likely the fixing film needs to be replaced. A few years ago Canon made the fixing films available to authorized dealers.The film itself should only cost a few dollars.The other thing might be the Drum unit itself.They are not so cheap.Independent dealers and service agents are generally cheaper than say, Ikon or Danka
Mar 26, 2009 | Office Equipment & Supplies
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Cannot print canon ir2200
toner waste bottle full. Take it out and clean it well particularly around the neck...which is where the sensor is.
Aug 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
436 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
